Hmmm... not too descriptive of your specific issues or desires.madnomad said:I'm starting to get a little bit frustrated with my CA,....
You'll need to give an exact list of all the features you use in it that you want to replace, so we can give you a list of the separate devices you'll need to perform the various functions.madnomad said:I'm starting to get a little bit frustrated with my CA, and I'm wondering if anyone knows of any good alternatives?
teklektik said:Hmmm... not too descriptive of your specific issues or desires.
Perhaps it's not the device but just that the Guide let you down somehow - which is not good - but that shortfall may be able to be addressed....
Post to the V3 Beta Thread - maybe some tweaking will fix things...
amberwolf said:You'll need to give an exact list of all the features you use in it that you want to replace, so we can give you a list of the separate devices you'll need to perform the various functions.
madnomad said:teklektik said:Hmmm... not too descriptive of your specific issues or desires.
Yeah sorry, I guess that wasn't especially contructive, and Tekletic, you've done a great job on the guide, although a lot of it is well above my level at the stage I'm at now, and at the beginning it completely fried my brain, although I guess that is to be expected if you're learning a new topic from scratch.
Here are a few ideas I'd like to see implemented in the CA v4 (any idea when its coming btw?):
A built in DC converter which can output 5v, 8.4v and 12v. I have spent soooo much time trying to find a solution to power my lights, and it seems like most people would love to power their lights from their CA, so this would save a lot of people a lot of time. It's also a pain having to conceal a bulky DC converter somewhere between the light and the CA.
I would like to see waterproof sockets on the CA to replace all the cables coming out of it. It's hard to know whether I should cut them off or if I'll want to use them at some point in the future.
It would like to see the screen replaced with a something a bit more up to date. LCD screens are pretty advanced these days and this one seems like something from the 80's (really not trying to be rude). It seems like the best idea would be to design it so an android or iphone could be used as the screen, and if this could be done via bluetooth then that would be fantastic. The mind boggles as to the new opportunities this would bring- music, GPS, rear view mirror (on screen), etc etc etc.
I think a few settings seem to be unnecessary and complicate things. Maybe I'm wrong here, but couldn't the recommended "gain" settings be calculated automatically based on the power limits you enter?
Rodney64 said:The problem with phones they shut down in the heat. So it needs to be its own identity. Yes sinking with the phone maybe ok but not as the screen.
Won't keep it cool with direct noon sunlight on the screen itself here in Phoenix. I've seen a few things killed like that. Some are temporary, and come back when they cool off, and some the screens stay dark or even solid black.madnomad said:I'd have thought the wind would keep it cool while you're moving, but if the phone was connected wirelessly you could keep it in your pocket on very hot/wet days.
Rodney64 said:Depending on what you are running and if you have the cash an adaptto mini.e would be the way to go. Just so more user friendly. It also has the controller. For 450 us dollars
amberwolf said:Won't keep it cool with direct noon sunlight on the screen itself here in Phoenix.
So does the CA, with the Cycle Analogger (or any other serial-port recorder attached to the CA's serial output).d8veh said:It's a really useful device because it logs all the data.
That's $150 extra though. CA plus Analogger = $300. That's a lot of money for some of us. Speedict is $123.amberwolf said:So does the CA, with the Cycle Analogger (or any other serial-port recorder attached to the CA's serial output).d8veh said:It's a really useful device because it logs all the data.
Even that is more than *I* can normally afford--I only have a CA at all cuz of the generosity of others, myself.d8veh said:That's $150 extra though. CA plus Analogger = $300. That's a lot of money for some of us. Speedict is $123.
Sure, sorry, I'll leave y'all to it then, after this. I just tried to present an idea those reading/posting might not have thought of.I thought this thread is supposed to be about alternatives to a CA anyway.
If the CA's control or other non-realtime-display features you want aren't in the controller or LCD, you could still use it and just mount it in the battery bag.They have their advantages in some circumstances, but I can't really use them anymore because the modern controllers that I use have LCDs, which leaves no room for the CA.
Only if they need to see that LCD--otherwise tehy could put it in the battery bag/box, and stick the CA on the bars. Depends on which info they need access to. MIght be they don't need either one.I guess this would be a problem for most people wanting to run with less than 1000w.
This is why I moved my CA2 from my cockpit to my battery bag. Then I took it out of service altogether because it was so bulky and it roughly doubled my battery bag’s rat’s nest of cables. Speedict certainly looks compact and more feature-rich, so I’m tempted to try it.d8veh said:I can't really use them anymore because the modern controllers that I use have LCDs, which leaves no room for the CA.
Download times are not fast. The last time I did it, it said it would be 37 minutes, but only took 5 or 10 minutes. I went and made a cup of tea after my ride, and when I came back it was done. I don't see it as a big problem as long as you can multitask.cycborg said:Looking through the main Speedict thread, there are a couple things that concern me that maybe you could address. First, it sounds like the data download time is really slow, like 20 minutes. Has this been improved? Also, there were some problems with inrush current damaging the device; any comment on that? Thanks.d8veh said:I can't really use them anymore because the modern controllers that I use have LCDs, which leaves no room for the CA.
