Cryingmadman
Can I use wheel hubs for any size rim or are they size dependent?
Thanks in advance
CryingMadMan
Thanks in advance
CryingMadMan
For an accurate answer, we'll need the specifics of what you are trying to do. What rim do you have that you are looking for hubs for, and what frame dimensions does the hub and rim / wheel have to fit into, and what axle type does the frame support?Can I use wheel hubs for any size rim or are they size dependent?
I don't really understand what you are attempting to do. Perhaps you could clarify it, step by step?Thanks I have the hubs already they are 36 spoke hubs thinking about changing the wheel size on trike from 20” to I am not sure maybe smaller or bigger they are 20” x 2.15 currently. The hubs are new
My electric trike that I build has 26” direct drive wheel up front and two 20” rear wheels was considering changing size on rearI don't really understand what you are attempting to do. Perhaps you could clarify it, step by step?
This will change the tilt of the trike front-to-rear, which will change the steering angle of the fork.26” direct drive wheel up front and two 20” rear wheels was considering changing size on rear
Sorry, I assumed you were talking about an ebike hub.My electric trike that I build has 26” direct drive wheel up front and two 20” rear wheels was considering changing size on rear
