Whenever you're dealing with a slime-filled tube and have to do anything with the valve (including air the tire up, step one is always to leave the tire with valve stem at the top, around the 1-o'clock position, until the slime runs down to the bottom of the tube.alpharalpha said:Initially that sounds genius but how would I do that as when I remove the valve air and slime are going to go flying before I could get that tube in there. I can't release the air with the valve core in place because the slime will treat it like a hole and block the valve (tried that before.) If you know of a way I can do what you suggested that would be ideal.
How long that takes depends on the temperature, but not long even if it's a little chilly.
On my old gallon jug of it I used to have, that was part of the instructions printed on it.
