emmgee said:The Axiom part starts at 13:15 in the video. Soooo good to see you together on the stage, deep respect and congrats!
There is no such thing as "pages" in the app. Just link to the actual post, or also give a post#marcos said:Jump to page 11 for the latest hardware
Hackey said:Hey marcos what is status of MTPA and flux weakning. I want to test switched reluctance IPM motor on this controller.
There is a link right below the line you quoted, it ends in [...]#p1458465 which I think is pointing to the post. Doesn't it work in the app? btw, which app?john61ct said:There is no such thing as "pages" in the app. Just link to the actual post, or also give a post#marcos said:Jump to page 11 for the latest hardware
I just stumbled onto Qt and am jumping in. Did you find anything online to help you start building or did you start from scratch? I'm confident enough in building the visual aspect but starting communication with the motor/controller/bms seems enough not to mention control.Hackey said:I have already setup qt and all stuff for firmware compiling and i am using ubuntu no issues.
Sent from my POCO F1 using Tapatalk
bigdaveakers said:Finally got chance to have a play with my board.....I wont post pictures as it is a bit 'lashed up' at the moment. My main concern is to get the resolver working.
Sadly it seems to be misbehaving
If the rotor is still it reads around 180 degrees, if I move it I get the trace shown. If I stop it goes back to 180
Any ideas?
Also I took a big deep breath and tried to detect the motor parameters and got the message that inductance was 0 - probably going to need some help!
Yep they will work just fine. Actually they are used igbts from big factory machinery.jlcortex said:Hello, someone has tested FF600R06ME3 from aliexpress?, prices are 1/4 the price at mouser! about 40€, is it possible?
Most likely counterfeit, and most likely its not worth the risk if a total fire costs you more that what you saved in those IGBTs.jlcortex said:Hello, someone has tested FF600R06ME3 from aliexpress?, prices are 1/4 the price at mouser! about 40€, is it possible?
HighHopes said:last week we passed 100kW at 350V on the dyno. @lewbowski, you're right about 45deg being a pretty decent default value for timing adjust.
arlo gives a once over tour in the video: https://youtu.be/hYvuRghNGTc
Major Milestone achieved.![]()
Lebowski said:HighHopes said:last week we passed 100kW at 350V on the dyno. @lewbowski, you're right about 45deg being a pretty decent default value for timing adjust.
I think what Arlo1 does here is not what I do...
I have a 45 degree rotation in the error signals of Id and Iq, this is fundamentally not the same as a 45 degree rotation in the resolver output... with the rotation in the resolver signal you will not be FOC anymore as you also rotate the wanted Id and Iq. With the rotation in the error signals you have the 45 degree rotation in the control loop (giving you the stability) but not in the wanted Id and Iq (so you remain FOC).
I have this 45 degree rotation in the error signals for both sensored and sensorless modes.
Have you ever seen a rotation being applied to the error signals of Id and Iq ?
Arlo1 said:45 deg rotation in the error signals but not 45 deg in the NON ERROR signals?
HighHopes said:i have not worked a lot with IPM motors. a little with axial flux. but mostly SPM and separately excited. so this whole salience thing, the details of making it ACTUALLY work is mostly new to me. we were using a fixed 45deg angle just for quick test and got really good results, better than was expected. but we changed that to now use MTPA algorithm that does a better job
Lebowski said:I think what Arlo1 does here is not what I do...
nothing that complicated, just textbook stuff. its meant to be open source afterallAn oscillation on the phase angle combined with looking at the 1st and 2nd harmonic (in the motor currents) of this oscillation?
