Lurkin
Page 23 http://www.energiecycles.com/pdf/8FUNmanual.pdf
That's good to read please come back and update your work? You have helped me to learn something!Gianvi said:I got yesterday a motor with problem in other parts but seems ok on the Mosfet side.
I will replace ASAP it and let's see what happens
Gianvi said:Hi Kris,
no, i don't think programming with USB can stop teh sensor.
Only thing check wheel size
The Magnet is well aligned with the sensor?
I have not understand if the motor works and you can use the bike, also with your problem.
No error message on display ?
Gianvi
This thread is about problems/faults and fixes. Not about installing new drivesAF7JA said:My Ba-Fang arrived yesterday.
Before mounting it, should I open it up and apply:
*white lithium grease to the plastic gears, and
*moly grease to the main drive gear;
* or put Mobilgrease 28 on both, as suggested in this article https://electricbike-blog.com/2015/12/23/mobilgrease-28-bbshdbbs02-because-a-good-mid-drive-is-better-seen-and-not-heard/
*or, just install it as it arrived?
My thoughts on this are split, there seems to be a strong consensus that some of the Ba-Fang units were not properly lubricated at the factory. Countering that is the many things are never quite the same after they have been taken apart and put back together.
opperpanter said:This thread is about problems/faults and fixes. Not about installing new drives
Check another thread, for example: https://endless-sphere.com/forums/viewtopic.php?f=28&t=50104
He's a grump, there's a few. Let it roll. You don't have to be friends.AF7JA said:content removed, apparently "problems/faults and fixes" is reactive, not proactive.
