Interesting idea, would like to see this discussed in greater depth.
Worth its own dedicated thread though
zukster said:I just built a little throttle cutoff harness for over-volted/watted motors that uses a mini 5v thermostat board, that cuts off the throttle when the motor internals hit 120 degrees Celsius.
LM YN Digital Thermostat Module DC 5V -10℃ to +210℃ Electronic Temperature Control Module Switch Waterproof Sensor Probe Dual LED Display Red+Green
https://www.amazon.com/gp/product/B01M1J64LQ/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
The board works off 5v and can use the VCC of the throttle wire to power the board. Then the board relay cuts off power to the throttle when over 120 degrees. Works like a charm.
I made a throttle cable harness that can be easily removed if the board dies on a ride.
The beauty about this is that you can use the throttle wires to both power the board and cut-off the throttle, making it a somewhat clean setup. I prefer this over techniques that cut off power to the motor or controller.
You have to open the motor, epoxy the thermostat to the windings, and poke the wire out of the existing hall/phase hole. Next I'm going to install the board into a clear plastic case to semi-waterproof it.
