waynebergman
I have been given an old PC so I have tweeked the controller settings to give a much more gradual ramp up in PAS power and also changed the amount of pedal rotation needed to activate the pas. Both of these feel much better now. I am only using two levels of pas from my display setting so this means I just enter these two levels of pas in the fields shown that are not blocked out.
Feeling the desire to get some front suspension on this bike
The IGH is working really well. My regular routine is to give a quick tighten of the axle nuts just to double check that they have not worked loose on there own. It can happen every 3 or 4 rides if you dont check them. I think with the braking forces and the motor torque working in two different directions things can kind of work loose if you don't stay on top of it. If your out on the trail and the nuts come loose the chain will come off of the rear sprocket under loads.
