Bafang M500/M600 thread
Sandur-Rx said:
Sandur-Rx said:
Where can I source a light cable
Nobody got that splitter cable?
If someone can help that would be great
You can try asking if they make you a special cable
https://www.e-bike-technologies.de/index.php/en/
Otherwise you can order Bafang cables from CNEBikes on Alibaba
I bought it from CNEBikes together with the motor.
In reality, closed systems are only those certified by the regulations, M500 for Europe and M600 for the USA.
For other models, the connection protocol changes, but the settings should all remain.
This is the Bafang BESST software controller setup page, and as you see there are all the settings.
When you connect the controller, only those provided by the firmware will remain.
CNe won’t ship a cable without a motor.
Wil try the other one now. Thanks for helping out.
Hi all
I have a question regarding the m500 motor. When the battery drops under 30% the Controller is limiting the current to 50%. Do you have the same performance with the m600?
Gesendet von iPhone mit Tapatalk
mirkoser100 said:
Hi all
With M600 under 20%
Hi Guys
I am looking for the bash guard and skid plate for my M600. I ordered separately frame and motor and i got wrong covers(marked with red arrows) :(
Instead I need to buy:
BG G520A
Do you know if I can get them somewhere ?
Chris
HI
Does anybody know an contact for bafang warranties ? i have tried: melody from dengfu, bafang "after sale support ", service@bafang-e.com, nobody answer ? does somebody have really tested bafang warranty one day ? i have a problem with the controler (i suppose) sometime i cannot switch off the display or mosttly most serious, i can't switch on, i have thinked it is the remote switch, but i have tested with another display/remote and it's the same problem.
Maybe correct motor with bearing part numbers?
In my M600 motor instead of the 16907RS there is another 6810RS, coupled with a 48x54x3 oil seal, in place of the HK2220 bearing, there is a HK 2212 bearing
Are there two types?
Inside the final gear is a 36x43x22 freewheel.
Hi. Have you encountered for the m600 motor sudden stop in pedal assist without error but when you stop pedaling for a second and pedal again, it will assist again? What do you think is the problem? Thanks
It has happened to me. I actually think it is a software artefact. In the way they measure and smooth the torque sensor data, it's getting a false zero. Stuttering and then starting again.
Can't be sure though. But it's happened to me twice both times in the same "situation" a very long steep climb high cadence, medium level assistance pushing hard on the pedals but trying to keep traction moving slowly, 6 or 7km/h
Anyways it's just a guess and not really a big deal. I've otherwise done over a thousand hard and rough km on m500 and m600 and this issue has only happened twice on the same climb at different occasions.
it happened to me again twice today. it only happen if from a freewheel then i pedal. it wont happen when i pedal always. but it also doenst happen often. strange
artyy said:
I felt the same as you described my diagnosis was as yours but then i tuned speed sensor precisely and voilà everything works fine and smooth... I suspect the reason is that speed is not read constantly and controller gives power inappropriately (so to speak... )
how did you tuned it?
I think ensure it is 10 to 20mm Gap.woth the magnet centred on the logo. The manual was attached earlier. Just look in there
Edit... Less than 10mm is NOT GOOD!!!! Causes strange errors
Andy
Andy
Thank you so much andy. Will try it
Andy
This is too close?
@CiDi
Hello, My bike is powered with Bafang M500.
When I connect InnoMaker between display and motor I manage to send info to bike. On the info page on diplay is speed limit 60km/h and graphic is displaying 60 km/h. I close the device and connect display amd motor directly and everything is still O.K. When I turn power off and on again, speed is reverting to 25km/h. What am I doing wrong. Please help.
When I checked the errorcode, I found that there are quite a few, 25 and 30. Maybe someone knows how I can erase the errorcode from memory. Maybe this is causing problems?
I’ve read that to calibrate torque sensor on M600 motor weight is required on the pedals.
Does anyone know proper procedure for torque sensor calibration?
I returned my motor to 14.6 firmware and it feels like pedal assist is not behaving same as before when I had original 14.6 firmware. ( before changing to newer version)
serafko said:
@CiDi
Only I have this problem, am I too stupid and should I know the solution?
