John in CR
100 TW
My wheel is almost perfectly true both laterally and circular around the axle, close enough that I could only mess it up, but it's out of balance. I look up a DIY way to balance, spin the wheel and see where it settles to find the heavy point. This 20mm axle hub spins an amazingly long time BTW. Then wrap some thick solder around the nipple opposite the heavy point. Nice and easy and I now have a perfectly balanced wheel.
I'm doing this because the out of balance condition reared its ugly head with significant vibration at about 85mph and up. That means it's messing up my video for you guys, but needless to say I was nervous about the vibrating bouncing wheel at such high speed.
Now that the vibration will be gone for a more serious attempt at my bike's top speed, I'm concerned about one of the lengths of solder flying off. I found this method as one for an old school DIY method for balancing moto wheels, but I don't know if that's enough to not worry. I'm expecting 105mph, maybe even 110mph as a true top speed at this voltage. Should I secure the solder with more than it's tight wrap?
John
John
