Russell
Scoot,
You didn't check the individual cell voltages before you bulk charged the packs? :|
-R
-R
Actually, yes I did, and they were all at 3.32 to 3.33 volts... not surprising to me actually as my other pack usually settles to 3.35 volts per cell after resting over night... even when they are out of top balance. i am getting the impression that this settling phenomena is pretty normal for Headways, but have heard others proclaim otherwise :?Russell said:Scoot,
-R
scoot said:Actually, yes I did, and they were all at 3.32 to 3.33 volts... not surprising to me actually as my other pack usually settles to 3.35 volts per cell after resting over night... even when they are out of top balance. i am getting the impression that this settling phenomena is pretty normal for Headways, but have heard others proclaim otherwise :?
scoot said:I fear you may be mis-interpreting my data Russel:? I wouldn't conclude anything particularly negative about the Headways quite yet.
Russell said:scoot said:I fear you may be mis-interpreting my data Russel:? I wouldn't conclude anything particularly negative about the Headways quite yet.
No I don't think I am. Take a look at Wookey's data above for a good example of the spread between the cells in a Headway pack without a BMS. By comparison my pack of pouch type cells without a BMS is showing excellent results so far. Granted my results are preliminary but the cell voltages I'm getting is what I want to see from any pack I construct.
-R
AndyH said:Russell - how did you charge and/or balance your cells when you first built the pack? How about you Scoot?
dnmun said:you should be able to repair your pack if there is any amount of tab left sticking out of the pouches. if you can solder to it, then do that, but if it is the aluminum tab, you can make a tiny clamp out of two little tiny metal bars and use screws at the ends to squeeze the ends of the broken tab between to make the connection.
if you decide to give up and use just 15S then how can you charge it? you are stuck with a big hassle.
in spite of that, if you wanna run on the 15S you can still use the BMS for discharge so you still retain some cell level protection by putting a jumper across the opto for the LVC signal and the HVC signal so it will not respond to their out of range condition.
So that seems to have worked nicely in that no cells got too high. High cell-sets are consistently highest. Charging was much slower (less than 2A after first hour) due to charger backing off much sooner. I wonder if I am seeing the effect Olaf reports of lower charge rates much reducing the tendency for the voltage to get too high? It did seem to take much lkonger to terminate than I expected. This gets back to the old thorny question of to what degree voltage represents SOC - if different charge rates change the shape of the curves that makes life more complicated. (like spotting 100%SOC with dV/dT on NiMHs which is much easier at high current rates).wookey said:Here is my data, updated to add charge after bleeding (to 54.5V)
Code:cell 16cycles bled to 2 cycles bled to id charged charged charged to 56.6V to 56.6V to 54.5V A1 3.335 3.338 3.338 A2 3.727 3.65 3.794 3.362 - too high 3.430 A3 3.335 3.339 3.338 A4 3.335 3.337 3.338 B1 3.430 3.561 3.367 - high 3.408 B2 3.679 3.65 3.718 3.368 - too high 3.441 B3 3.357 3.378 3.386 B4 3.753 3.65 3.821 3.367 - too high 3.505 C1 3.336 3.340 3.339 C2 3.341 3.352 3.358 C3 3.336 3.338 3.338 C4 3.335 3.338 3.338 D1 3.493 3.607 3.363 - high 3.399 D2 3.334 3.338 3.338 D3 3.335 3.338 3.338 D4 3.608 3.634 3.364 - high 3.419
recumbent said:I found that the best way to monitor cells is to check all cells at a moderately drained state, match up the lower cells with a single cell charger (i use a cellphone charger) Then check again fully charged.
The cells stay ballanced for many weeks of use, and if one is too high, I just drain it with an old car headlight with alligator clips attached as my resistor.
Now i use two CellLog monitors for my 16 cell pack, and never get into trouble that way. I've had two different BMS's destroy couple cells over the years. BMS's are not quite perfected either.
GGoodrum said:One thing I haven't seen mentioned here is having two cells that have the same capacity, but just happen to be at different states of charge. One thing periodic balancing does is equalize all the cells to the same voltage level. If you don't, and the cells keep getting farther apart, you end up with less and less capacity. If you at least have cell-level low voltage protection, you won't kill cells, but every time you run down to LVC, the cells will get farther apart.
-- Gary
