mrzed
Hi all,
I've been running 10 months now with a 9C front kit from eBikes.ca. Overall very pleased, but my 8Ah niCad pack is no longer giving me nearly 8Ah. I had a blown controller replaced under warrantee, so perhaps it did something to the pack on it's way to the grave, or perhaps I just was not waiting long enough for the battery to cool down before charging. In any case, I'm looking at a near future replacement, and might as well do an upgrade at the same time.
I typically only use 6Ah on my round trip, but would happily use a little more. I would also be happy to have the option of longer trips. I'm leaning to prismatic LiFePo4, because this is not a hobby for me, it is transportation, so I'd like a combo of plug and play, low total lifecycle cost, and reasonable upfront cost and weight.
Other lithium seems to have lower total charge/discharge cycles, and I'm not as concerned about minimal weight, so the power density is a minor advantage.
I am running a 20A controller, 36v. This is the one other part of the setup I'm likely to change, as the ebike is primarily a hauler, pulling kid in trailer, and I would like more grunt up the hills, so I will possibly be looking to move to 35A. I considered going 48V to get more torque, but I don't want the top speed. 35Km/hr with pedaling is fine.
I'm currently looking at a 36v, 15-20Ah pack. I figure this will give me super low C-rate for now, and enough headroom to move to 35A and really improve my climbing. I'd also be doing very shallow discharge cycles, and could keep it in the sweet spot for max lifespan. I'd be fine with lower Ah (10-12) if I could get higher C, at the same or lower prices.
Questions:
- Seems Ping is the default recommendation. Is there any other reliable cost-effective alternative? I want to save $ while still getting good product.
- I read something here recently about a new version of the ping battery (3.0) about to be released with improved ?? Is this imminent? Improvements?
- I know lithium has far less sag under load. What does a LiFePo4 pack at 36V/15Ah typically sag to under 20A draw?
- What is the calendar life of LiFePo4? I'd like this to last 3 years or better - is this reasonable?
Questions:
