BBS02 Throtle Programing
lcarron
100 µW
I have a BBS02 750 detuned to 18 Amp which is around 500W when using pedal assist. When using the throttle Is draw 18Amps and the power is around 800W.
I would like to limit the throttle to 500W as well. How can I accomplish that? I have the cable and program to tuned it but did not found any strait option but got an idea I need your advise.
- Limit the Amp to 10 on the basis setting
- set the "Keep current %" to 100% on the pedal assist tab instead of 60%
- Set the "mode" to current in the throttle handle section
Do you think that should work?
thanks in advance
[ I would like to limit the throttle to 500W as well. ]
Pick a PAS level that maxes out at 500W and refer to that on the throttle settings page??
