Tomblarom said:Just a reupload, since these tend to go offline very fast.tokoyama said:https://yadi.sk/d/hXqlI2_TjJ6PzQ
The firmware is provided by the service Bafag
CRR10E4830E105016.1_合并.bin
I flashed this firmware posted by Tomblarom:geosped said:Tomblarom said:Just a reupload, since these tend to go offline very fast.tokoyama said:https://yadi.sk/d/hXqlI2_TjJ6PzQ
First thanks for posting the FW. I have a few questions for the gurus. I have the em3ev 52v BBSHD. Is this FW compatible with 52v battery or does it matter? Also does this FW address the jerkiness on the throttle. I purchased my BBSHD back in December and mostly ride trails. The issue I have is the throttle is not smooth at at its very "jerky" I'd like to be able to ramp up the throttle instead of it being like an ON/OFF switch? Hopefully this make sense. Thanks again in advance.
sp1n4d0 said:Can confirm it works with 52V battery, has a current limit of 30A, and corrected the issue of PAS overriding throttle.
Thank you Tomblarom for sharing this firmware!
sp1n4d0 said:I flashed this firmware posted by Tomblarom:
CRR10E4830E105027.1_(latest)_190927.bin
Yes, tested with full battery 58.8V, it works.Magsy said:sp1n4d0 said:I flashed this firmware posted by Tomblarom:
Can I please ask if you tested at the full 58v+?
I don’t want to risk trying to rollback![]()
vicentmia said:Does anybody know how to save the original firmware before to flash a new software on the skt programming software?
MaNor said:I haven't done a test run with the 48V battery pack yet to see if I got rid of the sluggish response below 47V. I hope it will work as it suppose now![]()
Tomblarom said:Hello guys, fasterbikes provided me a newer firmware, directly from Bafang. I paid for it, but I want to share it here with you.
Version: CRR10E4830E105027.1_(latest)_190927.bin
I'm confused? I want my pas and throttle to work at the same time ? That's how my Ludacrous controller is set up and it's great for when riding with pas and need a quick boost.mike_k said:Tomblarom said:Hello guys, fasterbikes provided me a newer firmware, directly from Bafang. I paid for it, but I want to share it here with you.
Hi, just signed up to say:
HUGE THANK YOU!!! to Tomblarom
I have BBSHD 2021/03 production date and 52V 20ah battery pack.
Now, if anyone decides to upgrade from this file:
1. There are precise instructions and ST software included inside the file above, so I didn't have to download or look for anything else.
2. my upgrade was very simple, took just a moment, no problems or issues whatsoever - cheap cable (see picture by Maugerville in previous posts - exactly the same one with yellow jumper - I didn't have to remove it)
Now, my BBSHD after firmware upgrade:
- works with 58.8V fully charged battery, no problem, as it did before
- 30A limit, 28A before
- and the most important thing for me: THE THROTTLE / PAS PROBLEM IS GONE !!!If i just very slightly touch the throttle while pedaling it beautifully disconnects PAS as it should, there is no lag, it works very well. Release the throttle and PAS starts working again. SMOOTH AND BEAUTIFUL
. I was looking for a solution to this problem for a long time.
- and my very subjective feel is that the throttle response is different than before - it starts very slowly at first and ramps up at the end of the throttle rotation which I like a lot (my throttle settings: mode: speed, start voltage 9 - the lowest without error, end voltage 42, designated assist level 9, speed limit by display's command, start current 1%)
Tomblarom - THANK YOU!!!
