We'll just see how it prints on the existing bed first; then I'll try digging out my glass and see if that works, and if not, wait for a good sale on one of those ultrabases.
For now, I built a quick, easy, and almost completely free enclosure (cost me a few feet of clear packing tape that I already had, and an hour or so of time).
I started out doing some of the yard work, got too hot, then ducked into the shade of a shed and poked around, didn't find any of the plastics or other stuff I was considering building the enclosure from, but did spot a stack of styrofoam cooler lids saved from work (several are tossed out each week) to use for insulation in various things, and did a quick test fit, found that one of them is just wide enough to account for the entire width of the machine plus the cable on the side that has to move up and down. From there, with a bit of clear tape to tack it together as I went.
The "crossbars" on the bottom inside are there to space the enclosure away from the moving bits and keep it in place; the front crossbar has a duct carved into it to allow the front fan to draw in outside air to cool the electronics inside the printer base.
Old LED light panel from something (can't remember what) taped to the inside of the top nonhinged half of the lid, in case I need more light inside, but with the enclosure being white and light able to pass thru it some too, it isn't really required.
I am very likely to make an extension cable for the display to put it outside the enclosure, probably mounted on the right side panel; it's several inches too short to do that at present.
I still have to dig out the spare dryer ducting I'm pretty sure I still have and run that from the enclosure to another styrofoam panel that will fit in an opened window nearby that can be held in place by the window itself, with a fan installed in the window end to suck air to the outside from the enclosure to vent the heated plastics smell and fumes.
I'd also like to find the aluminum-framed flexible-plastic signholder I have somewhere and modify it to make the front door, isntead of the cooler lids, to see what's going on during prints in case something is going wrong. Until then, at least it is safe(r) from schmooslobber and fuzz attacks.
