Thank You....a few more questions please:The two motors are really close, and the RH212 might have an edge on efficiency with how I ride my bike, but I used the Grin simulator comparing the two using the ranges, speeds, and hill grades that I mostly ride. I don't really care about top speed, but I care a lot about acceleration and torque in the mid range, specifically between 25 mph and 35 mph for safety, when/if I need to ride among cars. With my controller and battery, the Leaf had a very slight edge on roll on acceleration at those speeds, and pulls decently up to 40 mph before the torque curve drops, but you can still feel some throttle response at 45.
Here's a video from my voltage sag testing, trying to limit sag to improve my 25-35 and 30-40 roll on. I need a better methodology, since it's hard to hold steady at 25 or 30 before hitting the throttle, but the CA recorded the sag, so good enough.
A. What winding/turn count is your Leaf motor?
B. What controller are you using and what is the peak amperage both battery and phase is it set for...if you don't have all the answers, that is perfectly OK, just let us know the answers you do have.
C. Based on the voltage on the CA display, I assume you are running a 72v/20s battery...is that correct?
D. What rear tire are you running...brand, diameter, and width? Just wanted this info so I can calculate the outside diameter of the rear tire.
E. What is your top speed on level ground?
Just FYI, I added a lot of extra explanation to my comments below so anyone not familiar with ebikes can understand better...I seriously doubt you need it
I like the methodology you used and the speeds you are running so I may basically copy what you have done. The only change I might make is a winding that has a little bit slower top speed and/or mount the motor in a smaller diameter wheel. The smaller wheel would slow the speed down a little bit as well as make it a little more capable of higher acceleration since the diameter of the driven wheel determines the final gearing.
Background if anybody is interested...when I started this thread, I intended to go with either the cheapest DD conversion kit I could find just to try a DD motor for the first time or something on the opposite end of the spectrum like the Cromotor/QS205 so I could get acceleration similar to my MAC. After considering how I plan to use this particular bike, the weight of a bigger motor and how it would have a significant rear weight bias that could affect the way the bike handles, and the battery required to feed a big motor if I really wanted to use it to the fullest extent it was capable of, I have come to the conclusion that a DD motor with about a 35mm stator and Statorade or ATF will be the best compromise...all things considered. I tried the AW 1,000 watt kit via Amazon and I would recomend it if anybody had a very limited budget and/or didn't need/want a lot of power. With the Z910 connector between the controller and the motor, it was really simple and easy to remove the rear wheel should I need to change a tire but the Z910 connector can not handle a lot of amperage without melting and the controller that came with the AW 1,000 watt kit was capable of 30A (battery current) and although I didn't have any issues with it, I would not want to go over 30A with a Z910 connector.
