+1
I can only say that 60amp at 72v constant is way too much
I ran it at this for maybe 3/4 a mile testing it in a fat bike and it got too hot to touch.
I had to turn the amps up to get things to spin.
I since disassembled to use the motor in a cx450. building...
Just checking Allinv:
What was your Phase/Hall combo?
Are you spinning your motor clockwise or counter?
Are you using a Ca v3 with it? If so what did you set the shunt for the 18fet at?
To try and answer your question from what I have read on here though.
People have given this motor about 4500w peak capability and about 1500w constant capability.
I would (and this is what I'll do next time) start out lighter duty.
I would run battery amp level at the 1500w continuous and phase amps at the peak 4500w.
Since your 20s to me this means 80v.
So 1500w/80v=18.75 battery amps. I'd do 20amps.
Then 4500w/80=56.25 phase amps. I'd just do 55amps
(Which by the way is 1:2.75 close to the 1:2.5 ratio that some like and china has pretty much standardized in there cheap controllers.)
I'm not experienced enough to make a judgment call on the ratio one should use, and this application will have it's own unique circumstances, but I think I would/will start out with this, but turn the phase amps down to 50.
So then ride it at that power level and get one of those lazer temp guns to measure the case temp.
I am not even going to try and guess what the correlation between the case and the winding temp would be but hopefully some one will pipe up who knows something about it...
Then keep slowly turning up the battery amps till either it matches phase or it gets too hot.
(others feel free as always to pipe up if this seems like a bad idea)
A LOT Depends on your reduction ratio.
Some have run 4:1 with success but some have gone though thorough explanation on the advocacy for 5:1.
Wheel size is a factor too.
