nutnspecial
Kudos, sweet! Keep us posted!
Saw your cx too diggler, those things have gotta be a blast!
i can probably make some if needed mate (got a cnc router) - made a 219 sprocket adapter for my norko build. sprockets are harder though, as they really need anodising to last very long...John Bozi said:I know it was mentioned some pages ago, but can anyone confirm this motor runs just as well in reverse?
I am contemplating running it via the disc brake side.
I was wondering if there is something off the shelf for the 420 sprockets too
this looks cool but for 410 http://shop.jakebike.com/9-hole-offset-SPROCKETS-for-rear-disc-setup-8898.htm
or anyone out there do custom sprockets or adapters for 420 that anyone knows?
thanks
allinv said:Diggler, thanks very much for the advice on the settings.
I'm in Ohio, so it will be a while before I can do some more experimenting (it finally got cold here [well, probably not as cold as Minnesota]).
Unfortunately, I don't have a CA.
With my Lyen controller the motor runs forward nicely (ccw viewed from the end opposite the shaft) with ALL the colors coordinated.
But since I am running it on the left side of my mongoose cx, I had to reverse it.
By trial and error I ended up leaving the phase green to green, and the hall yellow to yellow (swapped the others).
I am running an 8 tooth sprocket on the motor, and 30 on the 20" rear wheel, but I will be going bigger when I get back to working on it again.
I would also like to extend my swingarm and run a bigger wheel on the back.
diggler said:Did you get the bht shaft machined?
diggler said:O cool.
I'd rather pay a fellow ebike enthusiast than some run of the mill machinist to do it for me.
Be easier anyway because you already know what I'm talking about.
Could use that bar for mounting it too.
I've been looking at what is available.sn0wchyld said:i can probably make some if needed mate (got a cnc router) - made a 219 sprocket adapter for my norko build. sprockets are harder though, as they really need anodising to last very long...John Bozi said:I know it was mentioned some pages ago, but can anyone confirm this motor runs just as well in reverse?
thanks
Skalabala said:You must have misread I think.
"Running 11/50 to a 24" currently -just around 40mph top on flat @80v. 70/160 amps, rider+ bike 230lbs=
a rocket, and takes alot to get it hot (summertime and slowspeed highdraw aggressive stuff)."
bzhwindtalker said:If you guys are in europe I have 5 motors in stock, and 25 more on the way.
Price for motor with sprocket is 150€, with mount its 180€, EU shipping ~25€sraff said:bzhwindtalker said:If you guys are in europe I have 5 motors in stock, and 25 more on the way.
specs? price?
skeetab5780 said:actually after listening to the video a few more times it seems like its internal maybe off balance or a bearing or lams rubbing hah
