skeetab5780
anyone have a link or source for new big blocks? there is one on ebay that ships from France but its over $300 with shipping...
skeetab5780 said:actually after listening to the video a few more times it seems like its internal maybe off balance or a bearing or lams rubbing hah
Skalabala, your not running a cycle analyst by any chance? When I hooked mine up it run rough and would cut out at but was smooth when I run straight from Lyen controller without ca. Turned out it was an obscure amperage setting buried in ca3 that was causing my issues.Skalabala said:I still have my noise problem. Waiting for new controller on snail mail
https://endless-sphere.com/forums/viewtopic.php?f=30&t=72393
skeetab5780 said:anyone have a link or source for new big blocks? there is one on ebay that ships from France but its over $300 with shipping...
Dauntless said:skeetab5780 said:anyone have a link or source for new big blocks? there is one on ebay that ships from France but its over $300 with shipping...
1500w $75. http://pt.aliexpress.com/item/1500W-48V-DC-brush-motor-Electric-Scooter-motor-2-wheel-electric-scooter-motor/32368901296.html?spm=2114.02010208.3.27.7MnHju&ws_ab_test=searchweb201556_2,searchweb201602_1_10017_10005_10006_10034_10021_507_10022_508_10020_10018_10019,searchweb201603_9&btsid=bb8a3a2d-e185-4be0-82ea-478e2ecca668
Or $123 with a controller. http://pt.aliexpress.com/item/1500W-48V-DC-brushless-motor-and-controller-Electric-Scooter-motor-2-wheel-electric-scooter-motor-fit/32393515576.html?spm=2114.02010208.3.147.7MnHju&ws_ab_test=searchweb201556_2,searchweb201602_1_10017_10005_10006_10034_10021_507_10022_508_10020_10018_10019,searchweb201603_9&btsid=bb8a3a2d-e185-4be0-82ea-478e2ecca668
nutspecial said:.....
Thanks bzh. Should we check with him for the lower kV or are you selling them or similar?
I've only noticed you selling the higher kV ones, but like the mounting style (and pricing).
I thought 70kV might be less power capable, because they're slightly voltage limited by the size of reduction then needed. To use the same 6-7kw with 70kV I'd need a 12 to 110 reduction (or higher), or x2 amps+ to offset the lower volts.
Overclocker said:
skeetab i hope you don't mind if i borrow your pic
Question 1: is it good idea to do regen braking on this kind of setup?
i believe it's 52T to 11T
i plan to use #35 chain
Question 2: are Sabvoton controller compatible w/ this motor? using that variable regen really sounds interesting
10Nm from 8kg.......skeetab5780 said:Anyone try or think about trying one of these newer Golden Motor 3000w BLDC.
skeetab5780 said:Anyone try or think about trying one of these newer Golden Motor 3000w BLDC. They looks pretty ideal for my type of ride I want to build.
skeetab5780 said:Regen will be fine with this setup, just to warn you. The thing that bothered me the most with this setup was that there is no freewheel and the motor drag was always there when coasting. But if you add a freewheel then the regen is out the window.
(I would never choose non-fw middrive in first place, and running regen back through drive chain seems problematic)
