MP3 Fan
1 W
Hi everyone,
I have finally settled on a size of motor for my ebike. Going with a Bafang 500w rear. They have a kit with everything except the battery and Cycle Analyst which I'll want for $169 laced into a rim. That seems like pretty good deal unless there's something I'm missing. The problem is they seem to have two different pics of the same motor that look like totally different sizes. Please have a look...
http://www.bmsbattery.com/ebike-kits/586-bafang-350watts500watts-bpm-motor-e-bike-kit.html and http://www.bmsbattery.com/ebike-kits/348-bafang-350watts500watts-bpm-motor-e-bike-kit.html
I like the idea of 500w in a hub that looks as small as a 250 watt as long as it actually has the power of torque of the larger 500 watt hub. Is it just a mistake on their part or are these actually two different 500w motors where one is half the size of the other?
Question 2... what kind of speed might I see if I choose 201 rpm in a 26 inch rim? Ideally if I could get a mix of speed and torque I'd be happy. That being said 40 kph would be nice but I'd easily settle for 30 if the torque is decent. I dont live in a super cray steep hilly area but there are some inclines around and the less I peddle the better as I have damaged the back sides of my patellas and the less I peddle the better. Do they just change the gear ratio between the 3 rpm choices?
#3 http://www.bmsbattery.com/48v/655-48v-15ah-lithium-ion-alloy-shell-ebike-battery-pack.html seems like such a great deal for a 48v 10ah batt. That should get me decent range assuming I dont keep it pinned. Can someone tell me how I might calculate estimated range on this setup? Also... what kind shape are the cells in these packs?
and #4.... with the supplied controller will I be seeing an actual 500w? I only ask because in my research I see people saying that they arent actually seeing the rated wattage. And if I ever wanted to feed this thing more power to get more torque / speed do I just upgrade the controller to feed it more amps?
BMS site confuses me... things like this http://www.bmsbattery.com/front-driving ... e-kit.html where the pic shows the wires coming out the shaft but the diagram shows them coming out the hub. I'd like to know what I'm ordering exactly.
Thanks
Thanks
