Warren said:First off, the 2:1 and 1:1 ratio is marketing talk, not actual cable pull. Originally, Gripshift made twist shifters only. They didn't make derailleurs. Their twist shifters were made to work with Shimano derailleurs. They were originally used as bar-end shifters on roadbike drop bars.
http://stwww.bikemag.com/wp-content/uploads/2013/05/grip.jpg
They were much bigger in diameter. Then MTB's came along, and they made them for that market. They were smaller diameter to match flat bar grip diameter, which made them hard to turn, as the grip diameter is pretty small, and it only got worse as your hands got sweaty. They got bought up by a new company...SRAM, which also bought up an old-line chain maker, and some other component makers. With deeper pockets, and more components, SRAM started making derailleurs and twist shifters with more cable pull, to make the twist shifters easier to use. On any cable operated device, more cable pull is a good thing. Campagnolo derailleurs, from the 1990's onward, had more cable pull than Shimano. About the same time Shimano started making MTB V-brakes with more cable pull than traditional brakes. Anyway, the actual difference in cable pull is not double, but about 25-30% greater, as I recall. Definitely enough to screw up shifting, if the components are not matched.
amberwolf said:Just don't put enough of a spacer that the chain can fit between the hubmotor and the first sprocket....done that; sucks for several reasons.
Mmmm...you could add a big multiband antenna rig, and some nice big old Hammarlund gear with lots of knobs and vacuum tubes...oh, wait...that might be worse.Alan B said:It looks like something dangerous with all the wires and Lipo bricks, we will have to fix that.
40A? Yeah, that might even try to spin the offground bike in a reverse wheelie (or a stoppie on a front wheel), applied suddenly.Alan B said:On the regen braking, the throttle I'm using goes from 0 to 4V or so. In the 0 to 0.8V it should be doing regen. The software says it is doing braking and regen, but the deceleration of the unloaded wheel is very gradual, not at all like I would expect. So there's work to do on the regen to understand what is going on. 40A of regen should STOP an unloaded wheel almost violently, yet it glides down almost like it is not regenerating at all.
Best I can say is to check the circuit path from the MCU all the way to the shunt wire input PCB pads on the CA (I'll assume you've long since checked the actual wire from that point on ). Every time I have had a problem with impossible power readings it has always been a connection issue to the shunt (in my case at teh JST connector or crimps, but it could happen anywhere in the path).Alan B said:The CA seems to work, then breaks into nonsense current/power levels. 1,2,3 kw then 15kw. Tried low and high range. It has always had this problem, I tried the bypass cap on it as recommended, it still has the problem.
