Hi all!
First time poster on this forum, but i started this idea on a rc forum but figured i should probably spend some time here instead
so ive cut/pasted some of my earlier posts on rcgroups (slightly edited for clarity ).
A bit much in a single post prehaps, but i figure its easier to get you up to speed by cutting/pasting like a cheating highschool-student
Ive started sketching on the gearbox itself, as i will be fabricating this out of aluminium at work (4 axis cnc) but the sprockets and the rotary parts will be ordered when things clears for me..
Any hints/suggestions are most welcome, aswell as links to other gold-mines of knowledge
Ive been playing with this idea for months now and i simply cant shake it off..
The idea is to put roughly 1-1,5 kW of power, thru a electric brushless outrunner motor thru a gearbox.
The gearbox will be connected to the back wheel on the left side where the hub has mounting holes for brake disks, but will be fitted with a chain sprocket instead.
Top speed is 50 km/h on flat surface, but tourqe is more than welcome
I was hoping to use a simple servo tester as throttle (custom built), a 100A ESC and run it on 3-6cell series lipo (11-22v).
I will start by using my current batteries (2,5-3Ah 3s lipos).
a tad little prehaps but i would like to start with something cheap and readily available in case this project fails for some reason..
I have ordered a bunch of bike stuff, new back wheel among other things
this one has fittings for disk brake that will be used for the drivetrain instead.
The motor im buying is still unknown model (the seller havent still had time to look it up), but its a axi 41xx of some sort.
The current owner used the motor for a almost 3m wingspan depron/foam 3d acrobat on 3s 2Ah batteries in 2p, so my current packs seems to be a good starting option (3s 2,5Ah and 3s 3Ah) for paralell connection.
i have started a conversation with a swedish company selling belt wheels and belts (correct word??).
So as soon as i get an idea of what sizes to use, i will order the belt drive components and start building the gearbox house.
I also have a open question:
Is there a simple way that i could implement a on-the-go changeable gearing?
..3 gears would probably be enough, so i was concidering using a 3-5 gear planetary back wheel hub from a bike as a last gear reducer, but i wonder if its strong enough to handle the beating..?
and what gear ratios are thease hub gears normally?
and please apologize my butchering of the english language (3rd language) and please correct me where im wrong (life is a constant learning progress)
