The Blue Goose is completed! For now. Until it gets more bling or better lighting
Installing the CYC Photon was simple. A recumbent trike has a super long chain line, so aligning it exactly was not an issue. Packaging and mounting the non-standard LiFePO4 battery was a pain in the butt. I would not do it again. For any recumbent trike I suggest a standard Dolphin style Lion battery. For a charger, I do suggest the programmable Grin Satiator. I set my Satiator to 85% charge to preserve battery life. It stops charging when it reaches that level, and I've forgotten and left it connected for a day or so without damage. But it is not suggested.
The candidate trike, a TerraTrike Cruiser, has vertical handlebars and very limited space for accessories. Like none. I added 3" vertical riser from AliExpress (don't hate me) and it is not good quality but it makes space for the Minoura T-mount for the display.
Overall view. The ammo can looks dashing. Kinda hidden by the panniers.
Wiring harness was VERY challenging for a recumbent trike. It needed a 1 meter power extension, 2x200mm speed sensor extension, and the display/throttle was
barely long enough. Display is DS103 on the top left handlebar. Throttle is on the bottom right side bar.
I think the wiring runs are very clean and well hidden. I wrapped the 3 main cables in black spiral loom and pulled them underneath. Everything is held in place with industrial strength adhesive Velcro. I used the adhesive stuff for years for the lighting, and I trust it. No visible cable ties!
Battery, yeah, it's a beast. The LiFePO4 battery is 6" x 6" x 9". It fits in the larger 50cal FAT can, which has room for a 12V down converter for accessories. The angle iron from a bed frame is not the look I wanted. The ports are XT90 out, 12v out, XT60 charging. The black panel mount blanks were printed, from ebay.
I chose the LiPoly battery because I am new to electric bikes, and read horror stories of Lion batteries burning, and more importantly, they had to be watched while charging. I have so many things to do, caring for family, I would forget and let it overcharge. I wanted 52V 20Ah. The only LiPoly choice was from BTPower, soft packed, protected only by a shrink wrap. It is 6x6x9 in, and I spent over a month trying to find appropriate boxes. I finally settled on the huge ammo can, mounted cantilever from the frame, fastened at a third point in the back on the dropout arms.
