ghost1001
100 µW
Hi All,
I am new here and to ebikes in general and need help with C rates. I have read a lot including the battery FAQ and searched around but still don't get it.
If I am using 4 of the following packs, paired in series and then those pairs in parallel for a total of 44.4v and 20ah what will the c rate be in amps?
If you can also explain to me how you get that figure it would be greatly appreciated so i can look at other packs for my build. I plan to use an astro motor and have been told I need 200 amps in bursts.
Spec. Turigy nano-tech
Capacity: 5000mAh
Voltage: 6S1P / 6 Cell / 22.2V
Discharge: 25C Constant / 50C Burst
Weight: 769g (including wire, plug & case)
Dimensions: 163x49x48mm
Balance Plug: JST-XH
Discharge Plug: HXT4mm
Thanks
Kevin
Capacity: 5000mAh
Thanks
Kevin
