ryan
Methods is suggesting an alternative (simpler, reliable, cheaper) wiring scheme. Essentially 3 packs of 6S4P wired in series for 18S4P. I've reached out to him to confirm this is what he's suggesting, but here's my mockup of his notes:
Things I'm unclear about...
1) When I bulk charge, what do I connect to? Just charging leads off the main leads? Or at the LVC/HVC/Parallel boards?
2) Methods has a new HVC Breaker circuit that's supposed to go between your charger and the LVC/HVC/Parallel boards. But how do I connect the LVC/HVC/Parallel boards in series? Is there an extra slot for that?
3) When I balance charge, can I leave my pack assembled and just use the connections at the LVC/HVC/Parallel boards? (this would be way easier given my enclosure design)
4) How do I balance charge this pack?
5) Also, seeing as how I need to extend the balance wires, how do you recommend doing that?
HK sells 20cm JST extensions for cheap, but I'm going to need at least 5 balance wires that reach closer to 30-35cm (4 for each of the 6S1P packs at the back and one to go across the wheel to the other side). Should I buy a couple 10-packs of these and solder two together when necessary? Or is there another suggested method?
I really appreciate all the feedback and advice so far. This whole build is over my head, so I'm especially grateful for the all the wisdom shared here.
