ryan said:
Back to the LVC/HVC boards... let's say the right side is the "main pack" where I have 3 of your boards and 6 packs of Zippy LiPo 6S in 18S2P configuration. The left side then just has 6 packs of LiPo.
So the left side will also be configured in 18S2P. We will gang up the 2P's so that we end up with 3 JST 6S plugs - high, mid, low. We would then have to run those three cell level jumpers over to the main pack to ensure all 4 cells are parallel at the cell level. You would also have to run the main power and main ground over there.
ryan said:
Are you saying that I could add 3 "Method's custom paralleling boards" (MCPB, for ease) to the left side and then have 3 extension cables going from the MCPBs to the LVC/HVC boards on the right side? And then I can bulk charge via the right side's LVC/HVC boards?
The bulk charging goes into your main power and ground lines right? So that can happen on either side. Your balancing solution that taps into the LVC/HVC boards can go into either the main side or the aux side as well - since it is all in parallel it is all the same. The idea is just to parallel them up however we need to.
The LVC signal to the throttle would come only from the main side. If you choose to implement the HVC charge control that would also come from the main side. Basically - from an electrical point of view the pack is all just paralleled - even though one bank of your pack is physically separated - electrically (schematically) it is all together in one spot.
So if the distance is 2 feet you will need:
2 foot main ground jumper ( I suggest 10AWG+)
2 foot main power jumper
2 foot JST-XH-7 for cells 1-6
2 foot JST-XH-7 for cells 7-12
2 foot JST-XH-7 for cells 13-18
That is assuming the left side does local paralleling (which I will make for you free of charge. Simple small board that has 4 x JST-XH-7 board connectors on it.
The trick is building those 2 foot JST jumpers and deciding how to terminate the ends. I would terminate them with sockets (electrical sockets that plug into board mount pins - so male connector housing). I would offer to sell you one but the engineer who I employ costs $30/hour and it would probably be something you could do for cheap. JST-XH-7 jumpers are cheap. If I were you I would buy a bag full, cut them down the middle, extend them, sleeve them with a non-abrasion sleeving, mark them well, and go to town. Just dont mix up High, Mid, and Low unless you like buying / fixing stuff.
-methods
