This is progressing OK. I want to run it in oil so I'm waiting on getting some thin gasket paper and I need some varying length M3 screws. I finally made the high speed axle right and the gear turns over reasonably well (with nothing tightened properly and a battery drill providing the motive power), I will laser the mounting brackets next week and build up the test rig. My plan is to run it in on the test rig under load for an hour or so then case harden the gears and rebuild properly.
It will be tried on a yellow painted skip rescue town bike.
The laser cutting actually cost me £20 (less than I expected), all the bearings were £45. The mounting brackets and chainrings will be another £30 or so (quite big 3mm stainless thingies). Add a scrap motor, a 6s Lipoly, a "mystery" ESC and a thumb throttle, I think this thing is looking within the range of many home engineers (essentially guys like me with a lathe in a shed).
The assembly (motor + gearbox) is very compact, there's plenty of room to extend the gears if it proves necessary (the left crank is missing the motor by over an inch). I saw a comment along the lines of "why look at cheap outrunners when the "astro" motors are so nice". When the next post on the forum was pointing out the
cost of these things! You really do get astonishing bang per buck with the RC outrunners, cost per watt seems to be 10% c/w the astro. The key is making it driveable, which you can't really do with a modified servo tester (though in truth I have done thousands of miles with exactly that...).
Should get it spinning on load next week
