Before the downgrade NOTHING worked, no beeps no screen no faint click while turning on (even if all start items are deselected it does a faint tick).
Even glanced at the LCD in reflective light, in case the LED is toast, nothing.
C3, C4 ..C6-C9 didn't exhibit the LCD typical higehr voltages, another hint that nothing is working.
Now after the successful down/upgrade it works and gives me the melody and all.
I selected LiPo and even checked the calibration, but to no avail.
It simply shows no voltages whatsoever.
I have only 4s, will try the higher cells.
Please all remember this, when a CellLog is TOTALLY dead, but the USB/UART bridge is recognized, DOWNGRADE to V204, remove, reconnect, and then upgrade to V208.
However, my unit won't show any voltages, neither with 204 nor 208.
Vref is good (2.5V), all Op Amps give the right voltages to the A/D inputs, what could it be?
Is there a master reset/flush for this thing?
dnmun said:
do you have the initial splash screen come on? is there no led backlight at all or is there something that you can read on the display. someone might have turned the back light way down so now you cannot read it. do you have the disc with operating instructions for it?
