cell_man said:
Any suggestions for cell level test equipment that can test say 10 cells simultaneously and doesn't cost the price of a not so small car would be greatly apprceiated....
I just ordered a simple evaluation board with ethernet and ATMega32 proc for only 15$
http://www.pollin.de/shop/dt/MTQ5OTgxOTk-/Bausaetze/Diverse/Bausatz_AVR_NET_IO.html
Some clever folks wrote some nice webserver app for it and it should be easy ( for a software geek ) to build an automated battery testbench off it. It has 4 ADC's, 4 digital inputs ( for celllog alarms ) and 8 digital outputs onboard. There are some addon boards with more options available. If there is a question about the german manual, just ask me. I'm happy to help!
In fact I hope some would join my project and help me with the automated software
With such a board it would be possible to test and logg up to four 8s-battery packs at once. Each is observed by a celllog and they could be switched between charging and discharging using the alarm levels from celllog.
I'm thinking of using one charged pack as source for charging another empty pack and vice versa. This way you only have to add the energy which is lost by energy conversion. For a functional test you would only need a 1-2C testbench...
Or do you want to stress every cell with 30C?
I have played around with dcdc converters from 48V ( 36-75) to 3.3V @ 15/30A. They are trimmable up to 3.7V which is perfect for single cell charging ( thanks Jeremie Harris for the tip ). Think of using two 8s-packs as power source and charge any number of single cells with it.
Example QMT100-48-3.3N:
http://www.datasheetarchive.com/pdf-datasheets/Datasheets-7/DSA-123485.pdf
-Olaf
