GGoodrum said:These are quite handy little widgets.
I've been testing these as a replacement for the LVC and HVC detection parts of the new BMS we've been working on. What I did was use an opto, plus a few parts, on each unit, so that the non-isolated alarm outputs could be "ganged" together to generate the same sort of opto LVC/HVC signal. I'm testing this with an external "balancer" version of the new BMS. Actually, the charge control circuit is on a standalone board that goes in a small 1" x 2" x 3" box. This goes inline, between the charger/supply, and the pack's main charge connections. There is also a two-wire connection to the optos on the CellLog interface board, to pick up the generated HVC signal. Separate from the CellLogs and the charge control unit, is a another box with just the shunt circuits (24 channels...), and four fans. The reason for doing it this way is because with Lipos especially, the cells stay pretty close, so I don't always need to balance, but when charging, I still want the overvolt protection that the charge control circuit provides.
What I'm going to try next is doing a board for the three CellLog units that has all the wiring for connecting the three units in either an 18s, or 24s configuration, selected via some jumpers. This way I can use the same three CellLog units on both my 24s and 18s setups.
-- Gary
j3tch1u said:integrating the cell-logs and further simplifying/shrinking The BMS would be killer! are you going to rip the cases off and mount them directly to the board?
evblazer said:....Also I got my 9pin JST connectors from the train shop. I think it's too small it must be another series of JST connectors that is also 9 pins but a difference size. Wires are 24awg of smaller it looks like and the ones in all these pics look alot larger then that.
nwmtnbiker said:So, how many of you using the CellLog 8 have made the modification so that power for the device is drawn from batteries 1-8 and not just the first 6? I got my CellLog today and should be getting my TS cells mid-week. I guess I'll be opening up the CellLog and soldering so that I don't begin to get my cells out of alignment. I hope that the company makes a hardware improvement and corrects this issue this year.
nwmtnbiker said:.... you can order a ready-made 9-pin cable off ebay for $13 (with free shipping). I'm patiently awaiting mine--it sat in the Hong Kong post for 4 days before they moved it (don't know if they had a backlog due to the month-long February holiday in China). Using the tracking number, it's now supposedly shipped out of Hong Kong.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270470253072&ssPageName=ADME:L:OU:US:1123
nwmtnbiker said:Now to get the CellLog opened up to modify it so that cells 7 and 8 don't go out-of-balance quickly. SpeedEBikes, how do you get your CellLog units opened without damaging them? I've tried to gently open mine with a jewelry screw driver and it doesn't seem to want to open. I've not pried too hard because I don't want to damage it.
nwmtnbiker said:Scoot, thanks. I should have realized that the serial connection was all I needed to connect to. I attached the harness to one of my 2 12V 20AH TS packs, which have 4 cells each. Everything works well. I will need to wire these two packs in series as well as build my battery case. The ring terminals don't have any ID markings. They're just the right size for the bolts in the TS cells. Measuring them, they're about 1/4"--as I said, the harness is very well made.
GGoodrum said:One thing I'd like to see changed is a reduction of the amount, or elimination, of the hysteresis built into the alarm output. that way I could use these as HVC triggers with the charge controller unit. I've added optos to these outputs, so that I could use two or three of these together, to drive the charge controller, but the hysteresis is just too great. Even adding a big capacitor, to smooth out the voltage swings, isn't enough to make these usable for this application. Still handy little units, though.
-- Gary
scoot said:Gary, could you elaborate on this your observations just a little. We were planning on using the CellLog LV for triggering the brake circuit on a controller we have in our Goped ESR scooters. Since we haven't gotten to the actual testing, we are not quite sure what to expect. Any idea what we might run into there?
shinyballs said:Having problems wiring the alarm outputs of 3 CellLogs to a single piezo buzzer, powered from a 12v dc-dc converter. The alarm output wire(black) of each Celllog are combined together and connects to the converter's(+) and the other alarm wires(red) are again combined and wired to the buzzer's(+). The ground connects directly between buzzer and 12v converter.
This fried a CellLog when they're connected to the pack - this occurred even when the alarm outputs are not connected to the 12v power sourceDoes each CellLog has to to have its own buzzer and needs to be isolated? A wiring diagram will be very helpful!
