nicobie
Minor legend
Some people use the breaker as a system on/off switch. I've never done this.
It’s a matter of what risks you’re willing to take with the BMS. There’s a reasonable chance a short circuit will destroy it.BTW, if you are reading this glennb, I do keep wondering about bypassing the CB while being very careful not to short the wires. Go easy on me if you reply. Thanks.
In the event of a short circuit, the BMS should react quickly enough to prevent anything else being damaged between battery and controller. Just remember that BMS aren’t designed with this in mind, that their overcurrent protection is not intended to have to deal with short circuits..If I bypass the CB, will the controller survive?
It’s a large subject. I think you’ll find that amberwolf, amongst others, has written plenty on it.Do ebike controllers have their own built-in protection? Or is it generally not known if they have their own built-in protection from overcurrent? Has anyone tested this or verified it? Any subject matter posts about such tests?
AmberwoQUOTE: "Note that the controller to battery wiring being too small will not affect the breaker operation. Upgrading it to thicker wires will probably actually make the problem worse as current will be less limited by wiring resistance."
What is a breaker for then? I've read on diysolarforum.com (screen shots below) that CBs are to protect the wire only. No one argues on the solar forum about this. Does the ebike forum have a different opinion?
I'd like to know what the CB is for on an ebike? Is it to limit current, protect wires, protect devices or protect against a short? Which is the CBer's primary purpose - the one that's above all else?
Turns out the MCB in the video looks like the one in my moped! I finally took my failed (open circuit) MCB apart yesterday.Interesting video of MCB in operation.
Answering my own question, which was also asked in a comment in the video, reply says it's an arc arrester. That makes sense!What's the function of the red thingy? It has 9 metal plates mounted on insulators, not connected electrically to each other or to anything else.
That half of the 2 pole interlocking breaker failed open a long time ago, so I switched to the other pole. which recently started tripping while riding (happened a few times). That's dangerous so I replaced it with this one https://www.amazon.com/dp/B0C944KS8V?refLooks like it didn't work. Those contacts look pretty burnt.
Not only contacts were charred, plastic by the solenoid trigger (coiled magnet wire) also melted from the heat.Nice pics, thanks for sharing.
Those contacts are well charred. What was your use case for the breaker again?
It was not flipped that many times since it was not used to power up the moped (breaker under locked seat). Moped has a key and blue tooth remote to power moped up. Breaker flipped only when I needed to work or the electrical system. This suggest the breaker had high resistance from the factory which caused it to run hot constantly. You can see the melted plastic near the solenoid trigger.The lack of pre charge can also kill these circuit breakers.
Lack of pre charge causes charred contacts, charred contacts cause heat, heat causes it to trip, flipping it on to continue riding causes more charring.
That's correct! There's a trigger between the 2 breakers (riveted together- drilled out). You can see the black trigger on the left breaker.If I am understanding correctly? When one breaker is turned on, other one goes off. So that only one battery can be used at one time. How does that happen? What makes other breaker turn off?
Will your new 2 Pole breaker work that way? Don't think it will.There's a trigger between the 2 breakers (riveted together- drilled out). You can see the black trigger on the left breaker.
New breaker will not work that way, nor do I need it to. I have just one battery under the floor. With the warmer weather, getting 60 miles + per charge (LFP 73V 30 Ah). Space under seat is for storage.Will your new 2 Pole breaker work that way? Don't think it will.
The controller has 4x 330UF 100V electrolytics. Have you seen this post from E-HP On/Off switch autopsy where he used a 40A AC circuit breaker as a switch thousands of times with no pitting or burnt contacts? Why did mine burn and his didn't? I am sure his controller also has big capacitors.So, no never any current flowing when you switched off, but would've arced every time you powered the system back on due to controller caps? No precharge resistor? Decent sized controller with big caps? If so, that's a hard life for a switch and you might've been lucky to get 100 such uses out of it.
The contacts are high resistance only due to the charring, as eee291 explained. You have both a new and old MCB on hand, so can measure the resistance. It's a vicious circle, with the higher the resistance, the higher the heat, the higher the resistance.
You wouldn't have seen melting without charring, and charring without arcing, so best to address the arcs.
Less better would be to keep a tab on the number of switch activations and replace the MCB every ten or twenty times, but certainly not as many as 100.
Or better than less better, measure the switch resistance after each time you use it, with a predefined acceptable/unacceptanle Ohm figure in mind to determine when to replace the switch.
