agniusm said:How about making bottom plate a bit thicker (if its not thick enough) to drill out couple 6mm holes (for DIY modders) for water loop,
We're trying to make everything as small and thin as possible, as you can always bolt on extra metal if you want more mass and heat dissipation but there is no need to impose that on everyone by including a thicker heatsink in the design. That said, we do have a pair of holes in the design model which we didn't drill out in the above prototype. These go right through either end of the heatsink block and are intended for cable ties in order to quickly affix the controller to a bike tube. There's nothing stopping someone from instead jamming a copper pipe through this to invoke some liquid cooling, or possibly threading the hole and attaching pipe fittings.
Gab said:I like the anodised heatsinks on both sides of the fet. But i wounder how will you keep the screw from conducting to the mosfet housing ? its very easy for the screw thread to break through the anodiseing hence the screw will be alive and hence if it touches the inside of the fet hole it will conduct. Normal to220 bushes won't fit unless their is room above the fet?
Here's the cutaway view showing how that is done. The insulating shoulder washer is on the bottom piece and goes right through the mosfet body, so the screw can't ever touch the fet.
bowlofsalad said:Is it necessary to somehow isolate the USB connection that goes from a BAC500+ to a computer USB port?
If you are powering up the controller from a battery pack, then no need at all since the battery is floating. But if you are using a power supply to power up the controller when you have it computer connected, then it is possible to have grounding issue if the power supply output isn't isolated. And it's possible (known from experience!) to fry the communications port if the power supply is sitting at some high voltage relative to the computer when you first plug in the USB cable. Best practice would be to either have the BAC controller powered from a battery pack, or use a laptop computer which is not plugged into the wall, and then you'll never have to worry.
