Well, mine finally came!
Since I havent seen anyone do this yet... heres what it looks like when you get it.
Really I was planning on taking pictures the entire time I was putting it together, but once I started swapping the connectors to plug into my setup, I forgot to take anymore pics. :lol:
The big chunk of aluminum bolts to my scooter and acts as a spreader to the aluminum chassis that is out in the airflow. It also makes a decent heatsink itself to even out small peaks.
MrDude_1 said:
While we're wondering about things... anyone want to take any bets on me having issues with it driving a stock 80-100?
Now on to the less fun stuff... I am running a 80-100 in sensorless mode with this controller. I followed all the directions listed in the thread, and it works great... with no load.
So I took it outside and went down the street. At lower speed it pulled off smooth. there was a bit of a lag on throttle input, but I need to reset the CA to not ramp the throttle... I think thats the problem.
I went down the street fine, but on the way back, I decided to go a little faster. It accelerated smoothly, and then suddenly snapped off. (not the best feeling when you're balanced on a board doing an estimated 30mph)
I coasted most of the way back home and hooked up the controller. "instantaneous phase overcurrent fault".. uhh. ok. So I spent a good 45 mins looking around in BACdoor.
I got nothing. I cant find where to set the fault limit for Phase current, or how I am supposed to stop it before it gets to an overcurrent state.
I think my real problem is I dont understand the error.
Is it saying the motor is drawing too much current? I thought it was supposed to limit it to what I put in (entered 100A, but it changes it to 96A)
is it saying the back EMF of the open phase is too high? Because I thought that was also limited to less than, but similar to what it was putting in.
is it saying something totally different?
Finally, why does it only happen at high speed? I expect any current limit to hit when pulling away from a stop. I think I am misunderstanding the error.
I attached my BACdoor setup below. I am running the newest version.
Setup on the scooter is:
16s 20ah lipo (66v as ridden) -- rated to 400a draw, with 400a capable connectors, but I never pull more than 100a on it.
80-100 motor, running sensorless
Cycle Analyst V3 running the throttle/everything.... also the CA is showing a 7w draw even when the scooter is not being used, but I havent looked to see if that is the frequency draw from sensorless, or if shunt is incorrectly calibrated or if its something else.
I also watched the controller voltage on the laptop and its 100% spot on for my battery. No voltage calibration issue there.
