Controller and battery amps?
I have been looking at this battery. By the same person on ebay/amazon. But the thing I don't understand is the batteries are lithium but on the charger it says LIFePRO. will these chargers charge these lithium batteries? plus there is a difference of 57euro in price between ebay and amazon from the same seller same battery.
Sorry my bad there's actually a difference of one hundred and twenty two euro in price of the same batteries from the same seller. ebay/amazon.
Here's the listings.
https://www.ebay.ie/itm/18650-Li-Ion-48V-20AH-Rechargeable-Batteries-E-Bike-Power-Battery-BMS-6A-Charger/253556381627?hash=item3b092357bb:g:ZUMAAOSwvzRXzO1p
https://www.amazon.co.uk/dp/B00VTBC8Q8/?coliid=I1XDJZLXWXTTPH&colid=2KY1AMSNHVM76&psc=0&ref_=lv_ov_lig_dp_it
A LiFePO4 charger if set to charge Li-on battery's will charge them. It has to be set at a high enough voltage to activate the BMS. If the BMS does not get a sufficient voltage, it will not kick in and do it's job. If the charger gives the proper voltage then - No problem.
It does seem a bit weird though.
I have a v-power LiFePO4 charger that has been very dependable.
eBay is 55 pound difference. Also, eBay has free delivery.
:D
If a seller is selling quality cells he will proud of it and will tell you what cells are in his high-quality worth buying battery pack or else they could be cells only good enough for a laptop a laptop computer that just sits on the table and doesn't Propel anyone around. Meaning there are a lot of fake batteries generic low-quality that don't last very long we're just trying to help you not waste your money.
That battery is rated for 20amps and with 20ah of capacity. That's a very low rating for a 20 amp hour battery so they may be using lower-quality cells. A good 20ah battery should put out 30 or more amps. This may be a clue or may not.
rockypro1 said:
I wouldn't have a clue about what type of batteries at all. I'm going to buy a battery just know 48v and the higher the amps the better. I hope.
You got that right. My controllers are 40A and 60A. My battery packs are rated for 100A for one and 200A for the other. Your controller is rated for a max of 26A, so you need one rated fro at least 26A continuous, and the more the better. And that 26A is what the controller can draw from the battery. Has nothing to with motor amps.
As for name brand batteries, most ebay vendors advertize "high capacity" or "powerful", which is meaningless. I'd steer clear of vendors that state "samsung" without listing model number such as "Samsung INR18650-25R", which happens to have 2500mAh capacity per cell, and each cell has max discharge of 20A. For practical real world applications, you would never want to exceed 5A per cell max burst to preserve the life of your pack.
In short, you just don't know what you're getting if the vendor doesn't include a model number, and these companies all make batteries better suited for laptops and pocket calculators that would die an early death if used for high discharge applications.
Some cells have very high capacity (Ah) and some have very high discharge rates (A). Most are a compromise between the two. See the following table for capacity and discharge rating for commonly used brand name cells. Not all of these would be suitable for ebikes.
This is by no means a complete list, and misses many good cells for ebike applications. It is the best I could do on short notice.
Now for the Samsung 25R, I said the max you would want to draw is 5A per cell, but if you put 6 of these cells in parallel to make one large 15Ah 4.2V battery, your max amps would increase accordingly to 30A. In order to get a 48V battery, 13 of these parallel units would be put in series to increase the volts accordingly: 13 x 4.2V = 56.4V. Such a battery with 6 parallel groups (for 2500mAh x 6 = 15Ah) and 13 of these in series (4,2V x 13) would be denoted "13s6P, and such a battery would comprise of 78 18650 cells and weight about 4 kg.
My favorite model cells for batteries are MJ1, 35E, NCR18650PF, 30Q for high energy packs where you want a light pack but don't need something that can do 50A bursts.
For higher power, you usually have to compromise on capacity, and the Sony VTC3, VTC4, Samsung 25R would be better choices, and you wound build a higher capacity pack to allow higher safe amp draws.
I hope this helps clear up some of the mysteries surrounding cell choice. IMO, most of the ebay and amazon vendors are crooks selling misadvertised junk, and it is difficult to separate the wheat from the chaff. This is why we recommend dealing direct with vendors that actually construct the cells such as EM3EV.
It takes a LOT of nickel to handle 30A, so just because they have good cells doesn't mean the wiring and BMS is up to it either.
Bottom line - you need a reliable battery supplier, and a way to get the battery serviced. It is not uncommon for a battery to need maintenance - replace a few bad cells, replace the BMS, etc. Buying overseas is very risky. Many packs do not live their full life before they need attention, so they get tossed early because there's no good way to get service.
Hi,
Thanks so much guys. Thats some great information I never even knew there are so many types of batteries you can use that list is crazy.
I'm looking at a few batteries on ebay but looking with caution.
Hey take a look at this :shock:
https://youtu.be/OIs7C5tXERo
Thanks again Sean
999zip999 said:
Em3ev talk to Paul great batteries great support. No ebay No Alibaba.
I'll have a look, thank you.
My daughters boyfriend lives the UK. He says he knows a guy near him is into e-bikes. Says he will ask him about a battery and bring it over next time there over. Sounds good to me. Saves me a lot of hassle.
I am in the process of making the connections and here is what I've done.
I have an inline fuse holder and I'll be using a 20amp fuse. Do I need this? Plus are these wire connectors ok to join the wires?
Also I'm using a kettle lead to connect/disconnect the battery, the gauge of the kettle wire is a lot thinner than the other wires is this ok?
Is it ok to disconnect and reconnect the kettle lead as I only have a push button on the throttle NOT KEY and I'm afraid someone could just push the switch and you know yourself.
So would I need a switch between the battery and controller or will the kettle lead be ok?
Just to have it ready for a battery thanks
Hi,
Not going to use the kettle lead as the wire gauge is to low.
I'll be using the connection that comes with the battery
Yes I got a battery no sorry two batteries which are the very same. :D .
I bought them on ebay from good sellers, brand new 48 volt 20ah each. Got one waiting on other in the post. I tested it and its perfect.
Here's my new battery.
I'll be using wire connector blocks for the connections and a 20 amp inline slow blow fuse.
I'll also be using ferrules to make a good connection.
This is when I got my bike first, It was just a frame.
This is it now. Just have to do a few more bits and add batteries.
I bought a trailer on Amazon that's one of the reasons I built a 2wd e-bike.
See my dog tiny in the window he'll be going in the trailer also :)
Here's me and my bike and my new bike trailer.
Here's the bike all light up and my unicycle lit up as well :)
Oh forgot this is the reason I'm using the block connectors.
They seem to pass the hot test. Have a look.
https://youtu.be/2uYD8e7idnY
https://youtu.be/os66cID30Ek
rockypro1 said:
Hi all,
Looking for help about my e-bike.
On my controller it says 15 amp max, dose this mean that I can only use a battery that is rated 15 amps or less. And if I use a higher amp battery will it damage the controller.
Thanks.
The battery can be as many amps as you like as long as the voltage is right.
The controller will only pull as many amps as it needs regardless of how many amps are available.
Are we talking amp hour rating here or actual amp output?
The battery would need to be able to deliver a continuous output of at least 15 amps to power it.
If we're talking amp hours (ah), a 15ah battery would power it for 1 hour under a 15 amp load, 30ah for 2 hours and so on.
So the more amps the better just keep the voltage the same.
The same guy is selling the batteries on ebay also.
https://www.ebay.co.uk/itm/Risunmot...rentrq:b3f2e1cf1620a860caa4bad0fff8c635|iid:1 I can ask him on there.
I don't think I can ask on Amazon not that I can see anyway. I'll ask him on ebay see what he says.
The misses reckons that its better to buy it off Amazon, as I've a better come back with them, plus she's got a a bit of stuff off of them over the yrs. But I don't know.
I'd rather flush me money down the toilet that be codded by them. As I've had to sell me good car trailer and save a bit to get this battery. But ding to get it on the road, been out on it a few times and Wheres me power :lol:
No heard horror stories about them lipo's no thanks. also I want to get a good battery and be done with it hate messing around with lead batteries.
Me build Battery not a hope ha.
Do you build them? If you do would you build me one?
Sean
Don't buy battery packs off Amazon, mostly third party sellers offloading warehouse clearance/relabelled, battery could be donkeys years old, don't believe the Chinese ratings on battery packs, 60,000 mah for example, probably about 6ah in reality they like to add an extra 0 at the end!
