dudevato
I found I needed to resize my pics in order to post them. Soon I'll get some of the Solar Only boats I've messed with. For now here are 2 speedo's I've put together.
I've read on line (either here or elsewhere) that GPS units are not accurate enough to differentiate very small changes in MPH, say the 1/10's we might be interested in knowing about. These do and for $10 and a couple of hours of fabbing.
This first one is made from a kid's bicycle wheel (10" I believe) with 10 or so fender washers tack welded on. The High Tech part of it is a digital bicycle speedo from Walmart. They go for like $10 as I remember, and can be calibrated to the different diameters of tires you'd find on different bicycles.
I never got around to calibrating this correctly as I was only interested in seeing differences between motors, directions on the lake (into or against the wind) etc. I'd guess it would be somewhat actuate if you used the 8 or 10" dia these paddle wheels are.
If you make something like this you will find it is Very Noisy and very Splashy You'd want to swing it into the water, take a reading, then swing it out of the water. Again, very distracting in contrast to the quite of an electric boat
But I wanted something to keep track of my day's adventure so I started over. I wanted it quite and calm and I wanted it to look a bit nicer.
#2 is based on a plastic/rubber lawn mower wheel. I cut shallow slots in it with a jig saw and Shoe Goo'd in some more fender washers. With it being enclosed the noise and splash ought to be diminished as much as possible.
