crf450r 45kw race bike build
it’s a real shame in this power range… 3shul is taking forever delivering cc1000s (and under delivering on order qtys to distribution), Tronic has stopped development of their x24 and x54.
At least fardriver can deliver and that guy putting down 80kw or something with a 1081800 with his qs180. Proven results.
What build are you referring to that’s putting down 80kW?
well today I decided that instead of waiting for a reply from hackey I will order a new controller and ask for a refound on mine once he reply. On 3shul website it says that since I am not in europe I need to order from alien ride to have warranty on the controller. So I tried and at checkout it says that it can not deliver to my adress so I can not order. I would go with the fardriver but I need a vesc based controller for it to work with my bms.
I am waiting since 5 months for my CC1000 (replacement), so its like forever that´s true.
I got a reply from hackey. He looked at my settings and did not find something wrong and said that it was not hardware failure but bad settings. He gave me a discount for a new controller.
If it's bad settings, and not hardware, then the controller isn't broken and doesn't need to be replaced, it just needs for him to tell you which setting is bad so you can fix it. :?
the controller is dead. smoke came out of it and it does not power on anymore
And now I am trying to order but canada is not in the country list for shipping so I can't order:mad:
Then how could he possibly say it isn't hardware? :roll:
I think we can all say with fair certainty that when nosmoke.exe stops running it's not a settings problem anymore. ;)
He could mean that it is a software problem that caused a hardware problem.
Yes with VESC you can apparently input parameters which can damage the controller, and the motor.
Seems like there should be some protection against that.... :(
The firmware is open source, so controlling for every possible failure mode in different hardware setups would be pretty difficult. And the time it would take to customize the software for the 3shul controllers would drive up the price.
Yes, but what I mean is as he said it wasnt a settings error, and he agreed to cover the cost it probably wasnt the users fault.
It had an earlier fw and sw, thereby it could be a bug or compatibility problem.
Or so to speak, a settings problem that wasnt in the settings ;)
So hackey updated the website and I was able to order the controller. Lead time is 40 days
Update on this bike build. After over 2 months of now doing anything I started working on it again. Got hackey to tune the cl1000 and it works fine so I tought I will finally be able to finish the bike. So I tried the new bms I got from ennoid and guesse what IT DOES NOT WORKS! again. It reads 170v
What does your config look like? I've just been setting up my ennoid bms this week and noticed when I had one of the config settings wrong it threw the voltage out. Have you entered the bmstest command in the terminal?
Yes with bms test it fail every test. What settings did you find that can throw off the voltage reading? I think I set it up right or at least I did what ennoid told me to do.
It happened after I did the firmware update and the cell count and slave count were set back to the default 12s and 1 vs 28s.
If you've worked with Kevin on setting it up you'd hope the config should be correct. All my advice would be basic. But I'm happy to do an .xml compare in notepad++ or send through my config if you'd like. Are you still running the LV master and slaves?
no I changed to the xlite master. I guesse when the LV burned it problably burn the balance board too
