hjns
Cromotor Hubzilla ordered.
hjns said:"Diagnose before opening the motor"
Well, I put 5V over the black (g) and red (5+) hall wires, measured volts over the hall signal wires relative to the ground, and moved the wheel. No signal, 0V....
I also measured resistance from each of the phase wires to the brake disc. No resistance...
When I open it up this weekend, I am sure I will not like what I see.
Lebowski said:hjns said:"Diagnose before opening the motor"
the halls could be open-collector types, then you need pull up resistors...
http://en.wikipedia.org/wiki/Open_collector
did you try a sensorless controller with the motor ?
hjns said:No, I don't have one. However, with continuity between the phase wires and the disc brake, I am sure that even a sensorless controller won't be able to make it work.
Lebowski said:Ah, ok, sorry, I thought 'no resistance' was an open connection (so for very high ohmic)
Alan B said:Another Cromotor conversion.![]()
hjns said:BTW, I made lots of pics, but prefer to edit, upload, and comment them later when the build is done. Matter of priorities...
