This has been gnawing at me... and not just in terms of having the CA drive the controller. Back when we were all running 40A and a 5305 it was dangerous enough. I had my share of run-away throttle situations (like when the throttle came off my trike and it took off WOT) but with those setups the mechanical brakes were strong enough to overcome the motor.
This CroMotor and a 150A controller... uhg.
If we loose control of this it could be easy to lose your life - or worse loose your skin and limbs.
I am starting to think that reliability may be a lot more important as we go up in power.
I wonder if there is a module I could assemble that could be installed in the controller to look for "insane" situations and cut power. It could be a latching system - such that it needs to be reset. Usually before a bike goes berzerk it gives you a few warnings (which we of course ignore) but maybe we would be more inclined to investigate if our protection circuit tripped.
I did notice some settings in the XIE Chang software that would cut throttle if the voltage went above what was expected. These things are good....
We also have an advantage in that the motor will not operate if the controller goes completely bonkers - unlike a series wound motor that can just blast off if the controller freaks out.
I am apprehensive about giving over control to the CA.... Justin is thinking about 36V 20A bikes while he develops - not 100V 150A light weight motorcycles. Just a blip could literally land you on your back with this much torque. We are going to need lots of test monkeys to shoot into space before I put too much of my skin on the line
-methods
