Custom QS8 and QS10 antispark plugs with high resistors for high voltage antispark on/off loopkey
Sausalito
Custom made by the manufacturer. Higher resistors put in for higher voltage. Xt90s have much lower resistance and the antispark breaks especially with higher voltage and more inrush current
10$ each
Makes a good loopkey
I see them rated 110 continuous and 500 peak amps
I have to compare the rating and surface area to xt90s which are rated to 90amps, which is extra questionable
as the antispark connection takes away some of the main connection yet rated the same as the xt90 without the antispark.
(They come with the shrouds for both sides just not seen in the pics)
Couldn’t they make the antispark connection much smaller?
Getting QS10 connectors made with a 50ohm SMD resistor. The SMD resistor increases resistance as it heats so should be more capable.
One side of the connector is intended to be flat-mounted and the other side, with the resistor, is a regular plug.
The high resistance is ideal for high voltage. Keeps the contacts free of sparks and greatly reduces the inrush current into the capacitors so they don’t break and other bits on esc next.
PayPal 40$ to humminashadeeba@gmail.com for two sets with usa shipping which is practically the cost of them and shipping. Be sure to include all ur details and wants on the PayPal form.
A loop key must be the cheapest most reliable on/off switch and here available with decent size and an antispark good for high voltage unavailable anywhere else. (Jedi has a high voltage antispark but is not a simple plug like this).
Great security for a motorcycle and no one has a QS10 loop key.
They’re made with 5 watt resistors not 2.
