Glad you got your CA power issue sorted. That was certainly an annoying little bump in the road...
I'd like to say I've never accidentally smoked electronic gear, but that would be a really really big lie...
Done.
Button #1 = Preset #1 (This is actually 'decrement level', but since there's only 2 levels - it always goes to 1)
Button #2 = Preset #2 (This is actually 'increment level', but since there's only 2 levels - it always goes to 2)
EDIT - Oops, I misunderstood.
You want it to be a little more difficult... (which confuses me with regard to the 'emergency' remark...)
Anyhow, no can do, but - you can extend the CA button wiring and have remote CA buttons separate from any DigiAux functionality. This should work fine using those nifty buttons you found for DigiAux use.
Sure - just select 'Presets' for the AuxD function and set up the CA for two presets.irq said:Question about the Digi Aux Feature:
Presets can be changed directly through the 2 Buttons on the CA, which is nice but far away from my fingers in Case of Emergency.
Is it possible to configure a 2 Button Digiaux Setup to do the same?
Done.
