mrbill
I'm trying to figure out the values for these resistors in a Cyclone/Headline 24-48 volt controller.
There are 3 5-band resistors in parallel:
(2) black-green-silver-gold-black
(1) black-orange-yellow-silver-gold
My color chart says that 5-band color codes gives numbers for the first three bands, multiplier for the 4th band, and tolerance for the 5th band. It has trouble with "silver" as the third band or "black" as the 5th band. I don't have the instruments to measure them accurately. Can someone confirm these values?
Here's the color chart I am trying to use:
You may notice that the black-orange-yellow-silver-gold resistor is cut out (on the left). Paco of Cyclone did this to limit the current to 50A at 48 volts, so that the one-way clutch used in the "double freewheel" system is not overloaded.
The problem with this is that it limits the current to 35A at 24 volts (nominal), which is a bit low. I plan to use this controller at either 24 volts or 48 volts. So, to maintain the 50A limit at either 24 or 48 volts I'm thinking of wiring up a direct-connect cable for a CycleAnalyst, but I need to know the shunt resistor values accurately first.
Thanks.
Thanks.
