recumpence
1 GW
12-C said:Beauty of a build!
Dare I ask if there is anyone with a dual astro setup of this reduction?
Sorry had to...
Is there any way to do that?
The pedal drivetrain could never handle that much power.
Sorry had to...
aCeMadMod said:Beauty of a build!
Sorry had to...
yes i ask dave time of ask did not seem want to help get parts made for dual 3220 motor rc Tangent setup .
i can be done, i have all the parts just few to modding
hope hopeful dave will change his mind,
thank you all
recumpence said:12-C said:Beauty of a build!
Sorry had to...
12-C said:recumpence said:12-C said:Beauty of a build!
Sorry had to...
That was my first thought, but I wondered if there was anyone mental enough to try it
Sound is truly relative. I have gotten to the point that I purposely "Engineer in" the sound I am looking for. I do not add sound. However, if changes can be made to alter the type of sound or frequency of that sound, I do my best to engineer the sound the way I like it. That being said, I prefer a purposeful sound. If a design has inerrant sound, so be it. Again, I try to focus that sound the way I want it (nothing artifical), but I like being able to hear what is going on in a mechanical system.tangentdave said:A steel gearbox is the only way I've found to provide the robustness, efficiency and power handling in such a small package. The tradeoff is gearbox sound, which is on par with a cyclone gearbox as far as sound level (Eco Bike Adventures has a fleet of cyclone bikes, several riders mentioned they preferred the sound of the Tangent over the cyclone gearbox). It is relative though, at 500W it's like a freewheel, at 2500W you're moving/accelerating too fast for people not to assume a motor is involved, and at this power level the drive is usually mistaken for knobby tires on pavement.
I've never actually ridden a BBSHD though, just the little one.
-dave
tangentdave said:Sound is truly relative. I have gotten to the point that I purposely "Engineer in" the sound I am looking for.
Same here. I've tried a hundred different pitch angles and gear profiles to get this growl. Different tolerances here and there, more backlash, less backlash, no backlash, more pins, lighter gears, thicker grease, thicker ring gear; they all have an effect. End of the day, we're reducing 10-12kRPM to 250 and generating over 100ft-lbs of torque in an inch of space with only 3lbs of gearbox that's so tough nobody has managed to break one*. Other trail goers seem to prefer hearing me 30ft away when I'm moving at 30mph, but I've heard good things about the BBSHD if total silence is your priority.
*We've broken 4 or 5 high speed bearings out of 50 kits, I suspect from lack of break-in procedure, which I ask everybody to do now. These bearings have always failed almost immediately and their replacements haven't yet. These bearings are 6806 series, same as the outboard BB's, available in most bike shops and I can swap them out in 20 min with a screwdriver.
-dave
