2kg compared to ~1kg for the astro
The cyclone weight is more like the 3220 astro and hence power can go to more like the 3220 i.e 5 kw continuous with forced air cooling.
https://endless-sphere.com/forums/viewtopic.php?f=28&t=56666&p=845919&hilit=chupa#p845919
Since when does peddling make any difference with a high power bike above 2.5kw ? if you peddle or not will make no difference to the top speed or efficiency when using 2.5kw of power or more i.e peddle input is such a small percentage it will make no difference to speed or consumption, peddling is most useful on low power bikes or from take off and regardless of the motor-crank ratio all motors and cranks start from zero rpm so you provide input with 40:1 as well as 80:1. just that in the 40:1 case you have halved your top speed.
