So I just got the coolest toy.
This watts up meter...
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLMV0
it is avalable from hobbyking as well but it had been over 60 days on backorder.. of course i bought mine and 3 days later it got restocked... :?
http://www.hobbyking.com/hobbyking/store/__6380__Watt_Meter_Power_Analyzer_Watts_up_Ver_2_.html
Tried it today on the destroyer, which by the way is no longer an 8s destroyer but a 7s destroyed due to a dead cell on one of the cells.
Went to my favorite fast running area.. which is quite flat and did a couple loops, maxing out at 47.3 kph over a real riding distance of aprox 1200 meters.
Then I video`d the info as the watts up meter deletes the info upon disconnection.
The Peak Amps registered was under 54 amps. There is no information if this lasted a second or twenty seconds, however i'd be veri inclined to thing it was a fraction of a second.
The Max voltage was 27.5 volts
Max wattage was 1486 w (which of course adds up to the max amps X max voltage)
Here is a tiny vid of the event...
https://www.dropbox.com/s/cq7e1rqrcsu1act/20140503_143040.mp4
Disclaimer: 100% flat area, and startup on "very slow" acceleration. So there might be a difference if your setup is set to high accel or such...I weigh 195 lbs, the destroyer weighs 20, so we are talking of 215 lbs of combined weight. This is a single event, sincle reading and things might change tomorrow when i try it again at much lower speeds but much higher stop/start events... as well as crossing the overpass bridges and such...
For now i conclude.. the posibility of burning up my 2400 watt motor... are exactly zero (unless I manage to go like 80 kph on it
)... it will expect it will someday fail due to mechanical or manufacturing malfunction..not because of power concerns.Same goes for my 12s 100 amp esc.
Could have cabled all the destroyer using 16 gauge cable.. will probably change all my horribly tight xt90 connectors to the nicer and more manageable xt60s, am infinitly more confident of getting positive results using the "risky low" 90 amp 2 boat escs i just ordered.
Feeling cool and scientifiky right now... 8)
