daveweber34
- Joined
- Dec 23, 2013
- Messages
- 3
Hello Gentlemen and Ladies,
This is a fantastic website that you have here. I have been pouring over the information that you have here for the last several days but I still feel the need to post some questions for my own piece of mind. While many of you here may be used to dropping $1,000 on batteries, I am not and getting some confirmation on what I was planning to do will definitely help me rest better.
I modify stuff...kind of like you do...but different. Right now I have three kids aged 6, 4, and 2 and I modify some Power Wheels (Battery Powered Ride On or BPRO) for them to play with and keep me busy. I have decided to do a "big" build now that my wife is out of residency and I have time to spend in the shed again.
Has everyone heard of the Ripsaw tracked vehicle? No? Google it and check it out. It is flippin' sweet.
[youtube]http://www.youtube.com/watch?v=tlcenWPzsUU[/youtube]
I have many of the parts and components that go into this already ordered or in hand. In no particular order:
The body and the point-of-no-return item (welder):
I will be welding up a frame and suspension to go underneath the kids BPRO body.
The track (purchased, in transit):
The motors (Purchased. I am using four of these, two each side): Let me elaborate on these more. Ever heard of the EV Warrior electric bicycle? Well, maybe this is the wrong place to ask that, I hadn't. In all my research on this, I stumbled across it. Here are the specs on this motor (from Robotmarketplace.com):
The motor controller (in hand): A Sabertooth 2x60. It has two independent channels, one for each track. Each channel is capable of a sustained amp draw of 60 amps (120 sustained amps in total) with a burst draw of 120 amps per channel (240 total peak amps) for a few seconds.
At 24v (where this is going to be run at), the motors are listed at 1.55 hp. I am going to be running four of these. 1 hp = 745 watts.
So, each motor has a peak output of 1154 watts (1.55 hp x 745 watts). 4 motors x 1154 peak watts = 4616 peak watts.
I need to figure out what kind of peak amp draw that is. Since: volts x amps = watts. I can solve amps because I know the approximate voltage (24v) and total watts. So, the peak amp draw will be around 192 amps. That is inside the specs of my motor control for burst output, so I should be ok.
What I need to know about is the batteries for this. I have never used anything other than SLA/AGM batteries for these BPROs. I would really like to go a different route with this though because of the amp draw this can have and the weight SLA batteries would add.
I've talked to a another couple of guys, but I want to confirm it here. I was thinking about using some LiFePo4 Headway #40152, 15ah, 3.2v cells. To be specific, running 8s to yield ~24v. Now, I need to plan for a continuous current draw of 120 amps because that is what the DC motor controller can do. So, I should be aiming to limit the draw from the batteries to 2C, correct? If that is the case, I should be looking at building a 8s4p 60ah pack, correct? Would running a 8s3p 45ah pack and possibly drawing over 2C cause problems?
BMS? Check. I definitely plan on getting them. For the current draw that this could potentially do, I think I'd do a 50/100 BMS on each 8s pack and let my motor controller limit the current since that is built in feature it has. Also, just for your information, this motor controller has a built in regeneration feature where it recharges the batteries anytime a motor is commanded to slow down or reverse. Also, it has a lithium low voltage cut off at 3.0v (for the pack...it auto senses the number of cells in series).
Where are some reputable buyers? I am new to this. Anything else someone cares to comment on or suggest? I am open to anything you have to say on this.
If I am posting in the wrong place, I ask for forgiveness. Since this is a custom build, it doesn't really fit in the ebike, emotorcycle, ecar category so I placed it here.
Thank you in advance for your assistance.
