to7motor@SZ
New-ish here
Over the past year, we've received a lot of valuable feedback from riders using the DM01 in different environments: commuting, off-road riding, cargo bikes, winter riding, and long-distance touring.
One thing we've consistently seen is that riding style and gearing technique can make a very large difference in both ride feel and long-term drivetrain durability.
Like most high-torque mid-drive systems, the DM01 performs best when the motor is allowed to spin efficiently rather than being heavily loaded at very low RPM.
So we wanted to share a few practical recommendations that can help riders get the smoothest performance, lower operating temperatures, and the longest possible service life from the system.
In most situations, the DM01 performs more efficiently when cadence stays moderately high. A lower gear with slightly higher cadence will usually:
If you anticipate the hill and shift before cadence drops too far, the motor stays in a more efficient operating range and the drivetrain experiences less peak load. Riders coming from hub motors sometimes need a little time to adapt to this style, since mid-drives interact much more directly with the transmission.
The smoother approach:
This is especially important for:
We truly appreciate all the rider feedback, testing, and technical discussions from the community so far. They continue helping us improve both the hardware and the riding experience over time.
1. Keep Cadence Higher on Climbs
This is probably the single biggest factor. When climbing steep hills, many riders naturally stay in a harder gear and allow cadence to drop very low. While the bike may still move forward, this creates significantly higher stress inside the drivetrain and increases motor heat.In most situations, the DM01 performs more efficiently when cadence stays moderately high. A lower gear with slightly higher cadence will usually:
- Reduce motor temperature
- Improve climbing efficiency
- Reduce drivetrain shock
- Improve overall ride smoothness
2. Shift Earlier, Not Later
A common habit is waiting until the motor already begins to struggle before shifting down. In practice, earlier shifting works much better.If you anticipate the hill and shift before cadence drops too far, the motor stays in a more efficient operating range and the drivetrain experiences less peak load. Riders coming from hub motors sometimes need a little time to adapt to this style, since mid-drives interact much more directly with the transmission.
3. Reduce Heavy Full-Throttle Starts in High Gear
Heavy throttle starts in high gears create extreme instantaneous peak torque. Over time, this can stress the internal one-way clutch and gears beyond their design limits.The smoother approach:
- Start in an easier gear
- Allow cadence to build naturally
- Increase assist or throttle progressively
4. Use the Bicycle Gears to Help the Motor
One advantage of mid-drive motors is that the bicycle transmission becomes part of the drive system. Proper gear selection allows the motor to operate closer to its efficient RPM range instead of forcing maximum torque at low speed. In real-world riding, this often matters more than simply increasing peak power numbers.5. Long Climbs Generate Heat in Any Mid-Drive
Continuous steep climbing at low speed generates substantial heat in all compact mid-drive systems. If the motor becomes unusually hot during extended climbs, reducing assist level slightly or increasing cadence can significantly improve thermal conditions.This is especially important for:
- Cargo bikes and trikes
- Heavy riders or towing applications
- Low-speed off-road climbing
6. Drivetrain Maintenance Matters
Because a mid-drive motor shares load with the bicycle drivetrain, overall system condition has a direct effect on ride quality. A worn chain, damaged cassette, or poor shifting adjustment can increase noise, shifting harshness, and drivetrain stress. Regular inspection helps maintain smoother operation over time.7. Riding Style Makes a Bigger Difference Than Most Riders Expect
In many cases, the difference between a smooth long-term experience and premature drivetrain wear comes down to:- Cadence habits
- Shifting technique
- Heat management
- Gear selection
