Toseven DM02 Update: Addressing Nylon Gear Concerns
to7motor@SZ
🔋 Established
Suzhou
We’ve been closely following the community discussions around the DM02, particularly regarding the nylon gears and the shift to a 14A current limit. We appreciate the feedback, and we want to be completely transparent about our engineering choices, what happened with earlier units, and the updates we've made.
The Design Goal Behind the DM02​
The DM02 was built with a very specific ride feel in mind: lightweight, exceptionally smooth, and quiet.
To achieve that near-silent, natural pedal assist, we used a fine-pitch (Module 1.0) polymer gear in the primary reduction stage, rather than the heavier m1.7 setup found in our DM01. It was a deliberate engineering choice because the finer m1.0 pitch provides smoother engagement, and the polymer material heavily dampens vibration, eliminating the "gear-grinding" feel you often get from larger-pitch or all-metal gears.
What Happened with Early Units?​
In some early setups running at higher currents (16A–20A), some riders experienced premature gear wear. We looked into the root cause, and here is exactly what was happening:
Pushing high current through the motor, especially at a lower pedaling cadence (30–50 RPM), puts a sustained load on the fine gear teeth. Because the m1.0 teeth are smaller to prioritize smoothness, they have less thermal mass to absorb heat. Under repeated heavy loads, heat builds up locally.
High-grade polymer doesn't snap or shatter like overloaded steel, instead, it softens as it hits its thermal limit. This softening led to deformation and faster wear over time. The issue wasn't a structural defect with nylon itself, but rather heat-driven fatigue under specific, heavy-load riding conditions.
Why 14A is the Sweet Spot​
To address this, we ran extensive bench testing and real-world trials to find where the motor runs best. The data showed a clear pattern:
  • Thermal Stability: At 14A, the system stays within a safe, stable thermal envelope across a wide variety of riding conditions.
  • Efficiency: Pushing past 14A on this specific m1.0 setup hit a wall of diminishing returns. The extra current wasn't translating into meaningful additional torque—it was mostly converting into waste heat, which was the exact cause of the gear wear.
Setting the limit at 14A isn't about restricting the motor; it’s about running the system at its absolute peak efficiency-to-heat ratio, ensuring the gears last for years.
The Updates We've Made​
On the latest units and updated firmware, we haven't just adjusted the current. We've implemented several key upgrades:
  • Improved Thermal Management: The controller handles heat dissipation much more effectively.
  • Refined Torque Ramping: The power delivery is less aggressive at low cadences, preventing sudden heat spikes.
  • Upgraded Lubrication: We are now using a high-stability synthetic grease specifically formulated for MC nylon.
With these changes, the system still smoothly delivers its full rated 90Nm of torque, but does so in a highly efficient way. We are no longer seeing the wear patterns from the early high-current setups under normal riding conditions.
On my DM02, I thought I had set my T24 eco/city/sport currents to 12/14/16, but all three were at 18. Must not have saved them. Oh well, I reset to 12/13/14 o stay inside your guidelines. We will see if there's any difference in how it rides. I normally ride in Eco and below 16 mph.
I have the battery set for 36V (10S) and LVC at 30 because I occasionally run 36V, but normally I use a 48V (13S) battery. I would let the battery BMS protect the battery, but I rarely run it under 50%. The controller still sets max current, right.
Incidentally, how do the L1-L9 speed limits get activated? I notice L! is set at 10 or 12 kmh, but have never seen any power cutoffs.
14A limit is misleading. With fully charged 48V battery that would mean ~750W of peak power (54V * 14A)
In reality 14A is dynamically reduced according to real voltage. For 48V (nominal) battery real limit is between 9A-11A because latest firmware aims for constant limit at ~500W.
My recommendation is to get rid of those meaningless and confusing Amps limits in ECO/CITY/SPORT and use regular WATTS !
For example:
ECO - 125W
CITY - 250W
SPORT - 500W
Dear Customer,
Nice catch on the settings. This is actually a good time to explain some of the hidden intelligence in our DM02 firmware.
1. The 18A vs. 14A thing – why your save seemed to fail
The DM02 now has intelligent voltage sensing to protect the m1.0 system. Even if you set the display to 16A or 18A, the controller prioritizes thermal safety for the motor.
- On 36V (10S): it allows up to 18A to keep power up at the lower voltage.
- On 48V (13S): the firmware automatically overrides your manual setting and caps real output at 14A.
So it's not that you did anything wrong. The 48V safety cap is built into the firmware to keep the polymer gears from sudden heat spikes.
2. Why the speed limits (L1–L9) feel invisible
To get that smooth, invisible pedal assist, we optimized the torque ramp:
- Torque sensing: L5 is the main profile. It delivers the full 90Nm range dynamically based on how hard you pedal.
- Throttle: L4 is optimized for consistent thumb throttle power.
Since you usually ride under 16 mph, you're staying within the natural efficiency range of these high-resolution profiles. The power cutoff is designed to be very linear rather than a sudden jerk. That's why you haven't felt a hard cutoff.
3. On your 36V/48V setup
The controller handles current limits automatically when you swap batteries. But since you're running a 48V battery regularly, 30V LVC is a bit low. The BMS protects the cells, but I'd bump up the LVC for an extra safety layer if you're sticking with 48V long term.
So we recommend that keep your cadence above 50 RPM on climbs, let the auto-logic handle the heat, and your DM02 will run reliably for a long time.
Toseven Support Team
For example:
ECO - 125W
CITY - 250W
SPORT - 500W
Dear Customer,
Thanks for your question. That's exactly the trade-off our technical team deals with every day.
1. Why do we talk in Amps?
You're right that riders feel Watts, but our polymer gears feel Amps. Heat comes from current (I2R).
To keep the MC nylon within its thermal limit, we need a hard ceiling on current to prevent heat spikes during high-torque, low-cadence moments.
2. The 500W goal
You are correct. At 48V nominal, the system targets a stable 500W thermal envelope. We adjust the current dynamically based on real-time voltage, so extra power doesn't just turn into waste heat.
3. On the UI
The safety logic has to stay current-based to protect the hardware, but presenting power stages in Watts would be much more intuitive for riders. I'll pass your great suggestion to our technical team for future updates.
Whether you call it 14A or 500W, our goal is the same: reliable service for thousands of kilometers without melting the internals.
Thanks for your time and feedback.
Are there PEEK gears available for the DM02?
Dear Customer,
We would like to clarify that the nylon gear in our DM02 is made from MC Nylon. Unlike standard injection-molded plastics, MC nylon is formed through a chemical reaction inside the mold, which gives it a higher molecular weight and superior crystallinity. This results in excellent fatigue resistance and natural self-lubricating properties.
During the R&D phase, we evaluated PEEK as a potential material but identified several drawbacks for this specific application:
-Noise and Vibration
PEEK is significantly stiffer than MC nylon. In our m1.0 fine-pitch gear system, this stiffness tends to transmit high-frequency harmonics, which would undermine the signature near-silent operation of the DM02.
- System Wear
Due to PEEK's extreme hardness, it can be more abrasive to the mating metal motor shaft during prolonged high-speed rotation. In contrast, MC nylon offers a degree of mechanical compliance that helps protect the entire gear train by absorbing micro-shocks.
- Heat Management
While PEEK’s main advantage is high thermal resistance, our design focus was to address heat generation at the source via the 14A firmware update. By keeping the system within its optimal efficiency range, MC nylon operates well below its thermal limits, making the added cost and noise of PEEK unnecessary.
We believe MC nylon is the optimal choice for the DM02’s design goals. Combined with our latest firmware and high-stability synthetic grease, the durability issues seen in earlier high-current configurations have been resolved without compromising the smooth, quiet operation our riders love.
As a result, we do not currently offer PEEK gears, as MC nylon provides the most reliable and refined performance within the system's 14A design parameters.
If you have any further questions or concerns, please feel free to reach out.
Have a nice day!
Thanks for the elaborate answer.
What grade of MC Nylon do you use ?
Dear Customer,
Glad that made sense. On the gears, we're using a gear-grade MC Nylon paired with our fine M1.0 tooth design.
With the right grease, it handles wear and heat well without getting noisy.
