Doctorbass
UPDATE 22june 2012
Motor is almost completed
- Stator was pressed to remove 3mm width on each side and is now 62mm width
- The clearance for each side between the side cover and the stator winding is 3mm
- The pipe on the axel for the liquid have been replaced by polyethylene tubing with 0.200" I.D.
- The flow rate with the 50 psi pump is still impressive with only 0.200" I.D for couples of inches long for these pipe.
- The hall sensor connections upgrade is done and is made with a PCB and some 24 AWG Teflon skin wires
- The Phase wires will be 3 x 10 gauge Silicone Turnigy wire
- The BBQ temp sensor will be installed on the winding.
- I also plan to put some Thermally conductive Silicone between the winding and the stator armature to have better heat transfer.
- I will put special motor purpose varnish on the winding and all exposed steel parts.
- The 2 x 6005 SKF top quality bearing are installed in teh side covers
More to come! :wink:
that motor will be on the road soon guys!
Doc
Doc
