MitchJi
Hi,
Quieter (vs 11t)?Miles said:You might consider changing the chain drive to 13t : 92t?
You mean again? :lol:Miles said:Yes, quieter and smoother..... Assuming stealth is STILL a factor........?![]()
deecanio said:hi mate,
frock motor was indeed a bmc, their known as puma's from the uk source (teamhybrid).
i only have an old casing left, the last one i had died a tragic death when bob jumped it down 3foot or so and had partial throttle on when landing, peanut gears followed by a complete lock up due to double quick swap up with hammer :lol:
they are pretty damn good tho, for a frock motor
D
yes it's been painful waiting and waiting but im finally getting my bits together for another crack, allbeit with an sram
liveforphysics said:The Dual Drive is not the Stormy Archer. .
deecanio said:i think i need a fine washer to seperate their bodies as there is slight contact, any thoughts?
D
Thud said:D,
I am curious, you want the multi speed hub for the Pedaling side of your serial drive set up.
Is that correct?
Just wondering what the weak points of your previous set up were, and what the ultimate set up you are striving for entails.
( I know its in here some where.....seem to be a few tangents in this thread :lol: )
I have an anchient shimano 3 speed (before the word NEXUS was concieved) and am modifying it to put 1 or 2 freewheels onto. I will post it on my next "build" thread.
A short description is: grinding the hub back where the current sprocket is mounted with the circlip and welding a 1.375 x 24 threaded section onto it.
The spacing is looking fine for 2 freewheels.(haven't decided if i will include pedals yet) pawls are easyly replacable & look to be the weak link in my old shimano.
If you are off road, I have to think you would want the lightest set up you can get.
