safe said:First you want me to drop the discontinuous voltage effects because "you don't need so much precision" and now you want to add new formulas to simulate the effects of the wires?
Yes of course !!
No you are totally wrong.safe said:Now you seem to be just fooling around.
Keep in mind your motor have 25 mohms only at this example.
So if you add next 20 mohms than it totally change your duty and duty average current.
You have to keep in mind that current must flow through controler's switch (FET/FETs ) so you have no magical current multiplication.
Try to do calculations for 10 mohms wires resistance, 2 mohms switch resistance, and 3 mohms capacitors bank Rs (serial resistance).
And dont forget apply internal resistance for 40s3p cells packet at yours simulations of course.
In other way it is completly useless !!
When you include the primary parameters as above it is still will be simple and not precise but far close to reality and valuable.
safe said:That's okay, a little fun at my expense is fine... and the "minimal" spreadsheet is an idea I had for a while anyway. It's nice to have a simple version that people can easily figure out.
The "minimal" version is very basic and is "good enough" for most people who just want a "ballpark" answer to how their motor works.
[/b]
Its good enough for people which doesn't know what such simulation do and what don't.
You cannot arbitrally choose (fundamental) parameters and skip other (the same important or even more).
Try to solve simply RL cirquit and skiping R or L.
If you do it you get a nonsense. The same story is above.
Apply all important parameters as i said above and show me example with average tork is 0.001 Nm greater in PWM mode than at continous mode when you pump the same amount of energy from the battery at both cases.
If you could show such fenomena then Nobel Prize is yours. :wink:
