Hi CDCowardlyduck said:I gave up on my carbon belt for now and switched everything back to the old one.
I will have to wait till I get the larger rear sprocket or swap these parts with someone else.
I can't recall the setting you mean, but glad it's more torqie for you now.Joe said:CD, I changed the Torque setting from standard 30 to 50. Made the human torque max 300. wow Gonna have a look to this direction. The pull from low speed to high is better.
PS, took it apart cleaned and degreased, re-greased and then re-assembled. I didn‘t take a photo before and also has 5 attempts to get it right. You can hear when the belt is not aligned perfectly. Seriously the HL belt doesn‘t make any noise.
I think I should get a HL belt. Where did you get yours?
Cheers
Cowardlyduck said:.
My LMX isn't seeing much use lately...but I now have around 160 3.5AH 18650 cells spare I should be able to use on a big battery build for it at some stage. Might not be for a while yet still but at least I've got the cells now.
Cheers
100% Building it is certainly high on my priority list for those reasons...building a 20S12P pack for a Bomber atm then gotta try and finish my BikeE AT build, then fix my house up a bit, aaaand then I should get around to the LMX battery.briangv99 said:You'll love the bigger pack once you get time to build it CD. The reduced load on the cells is worth it alone, the 3500 cells struggle to keep up with only 5p. My 9p pack is much much happier, holding higher average voltage and never gets very hot.
TorEddy said:@Cowardlyduck I just installed the belt drive with the new carbon belt. Does the 15T sprocket have the correct profile for the Carbon belt? I installed the 14t sprocket for now, but it would be nice to know if the 15t is compatible with the carbon belt.
Xtr6 said:Had a silly problem with the Micro SD card. It was 128 GB and this was the problem. Took a older Micro SD 32 GB and Update went fine. Please make first a update from youre old programm. This is simple to do. Then just load the latest Firmware. It really makes you Glad you did it, The new Firmware is super. Especially the possibility to create youe own trhottle curve.
I also got the bonus off having 0,5 Kw power extra. The bike is now max. 3,8 Kw.
Runs lovely as before but now even better. Love the Nucular controller.
That came out very nice and cleanTorEddy said:I just completed my LMX64 upgrade.
Silixcon controller with display and full twist throttle, belt drive, new 160mm crank arms, new rear wheel and re-routing of cables.
The Silixcon is attached with screws and thermal paste.
I'm pretty happy with the clean cockpit and wire routing.
jimmywazer said:but I'd like a bit more power for my type of riding... so my Question: would you suggest a LMX161 which has more power + a larger battery, but is not stealthy so I might get myself in trouble with it. Or is there any possible way to get more power/torque out of the LMX64 (mine is currently at 2.5kw max./50A, 40mm motor, Nucular controller 12t front 100t rear sprocket with a 850wh battery)? I have one of the first prototypes which LMX sold. Has anyone maybe built a 1kwh battery that fits the bike? And any suggestions to get more power/torque out of it? Thanks in advance
jimmywazer said:Hey I am a happy LMX64 owner since almost 2 years now. I mostly use it to ride it like a stealth motorcycle in our forests (throttle only, unless I ride with friends) since motorcycles are illegal to ride offroad here in Switzerland, which is a shame. When I pass strangers with my LMX64, I get either no, or positive attention (with the chain setup). And now don't get me wrong, I love this bike and I would defenitely buy it again, but I'd like a bit more power for my type of riding... so my Question: would you suggest a LMX161 which has more power + a larger battery, but is not stealthy so I might get myself in trouble with it. Or is there any possible way to get more power/torque out of the LMX64 (mine is currently at 2.5kw max./50A, 40mm motor, Nucular controller 12t front 100t rear sprocket with a 850wh battery)? I have one of the first prototypes which LMX sold. Has anyone maybe built a 1kwh battery that fits the bike? And any suggestions to get more power/torque out of it? Thanks in advance
Cowardlyduck said:Some hectic bush bashing, flat battery and insane jumps not taken made for an awesome ride on the weekend...I really need a bigger battery
Rix said:Since you rode until your battery was dead, that means you had great ride CD.
briangv99 said:Rix said:Since you rode until your battery was dead, that means you had great ride CD.
Even broke out the MSR tow strap to get CD the last couple miles home Rix. Must have been a strange sight to see an while in tow
It looked something like thisRix said:I would like to see the video of that :wink:
Cowardlyduck said:It looked something like thisRix said:I would like to see the video of that :wink:
Cheers
